What should I run
Old Oct 20, 2005 | 08:03 PM
aulphielt1's Avatar
What should I run
I have sfc, bmr xtreme duty ta, 4:10, jet hot lt custom 3" exhaust centerforce dual friction clutch, Cai, Air foil,slp short throw and a pair of housier quick time slicks. Also my moter is stock.
Old Oct 20, 2005 | 09:14 PM
Mean Green Z28's Avatar
Re: What should I run
what kinda car? year? ... err, mid 13's
Old Oct 20, 2005 | 11:35 PM
MarkyMark's Avatar
Do you still have the 10 bolt? Slicks and a better clutch with a good launch could spell disaster. If you hook up good and everything holds together I could see a low 13 with those mods. Do a little weight reduction and get a mail order tune and a high 12 could even be possible.
My info is based on the fact that you have an lt1 btw, which you didn't specify.
Old Oct 21, 2005 | 05:13 PM
aulphielt1's Avatar
Ok My car is a 1995 Z28 with no options. I even eliminated the ac and the air pump when I did the header install. When i just had clutch,gear Ory and shifter I ran a 13.8@100.
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
