What RPM to launch at
Old Dec 11, 2008 | 11:56 PM
TBSPW's Avatar
I race here and there but never fully launch my car...basically im not sure where i should rev it up to to drop my clutch...usually run some nice street tires and i have a full bolt on car...any suggestions?
Old Dec 12, 2008 | 05:46 PM
AutoRoc's Avatar
Sorry for a lack of actual advice but I'd get some sticky tires first, even if they are track only slicks. Otherwise, your best 60ft time will be by slipping the clutch at it's optimum rpm all while trying to not spin street tires. Could be 2000rpm, could be 5000...It's all in how good you are at slipping the clutch/not bogging the engine/keeping the non sticky tires planted.
Tires that hook hard will let you forget about tire slip and clutch slip. You'll be able to test different clutch dump rpms and see where it does not bog. Depends on power/weight/gearing. goodluck!
Old Dec 13, 2008 | 02:07 AM
TBSPW's Avatar
yeah ill play around at my jobs parking lot and see what i can do....ill start lower and just work up till i find a sweet spot...oh and dont worry my job let me do donuts in the lot just because the manager wanted to see it.
Old Dec 13, 2008 | 08:10 AM
IrocSS85's Avatar
just dont expect the parking lot to hook like the track. at all. unless you stage an actual burnout box and starting line with some VHT! now that would be fun.
Old Dec 13, 2008 | 11:07 AM
TBSPW's Avatar
lol...yeah that would be nice to have at work...but im just trying to get the feeling down more than anything...anyway most of our races are on this side street near my house...dont worry its just some creepy road with no houses or anything even near it.
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
Daluchman1974
Sep 11, 2015 06:12 AM
