What RPM to go through traps in?
Old Aug 1, 2003 | 11:55 PM
94foormula's Avatar
Is it optimal to go through the traps right at peak power? or is it better to go through a little after, say 300-400 rpms after?
Old Aug 2, 2003 | 07:46 AM
TedH's Avatar
You want to be going through at peak power. Revving higher than that is simply rough on equipment.
Old Aug 2, 2003 | 10:04 AM
Stephen 87 IROC's Avatar
At the top end you should be going through the traps at or a little after.
My shift light comes on at 6800 and I cross the finish line at 6800. I should really be crossing the finish at around 7000. It all really depends on the hp curve since the torque really drops at high rpm.
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
Daluchman1974
Sep 11, 2015 06:12 AM
