what kind of 60' should i shoot for?
Old Oct 20, 2004 | 08:08 PM
godofdragons's Avatar
i still learning how to launch correctly and i know my 60' is bad. ive been running 2.3's on 315/35/17 nitto DR's and stock suspension. what can i expect it to get too as i improve? also how much would sfc's help me given my current skill level?
Old Oct 20, 2004 | 09:04 PM
Fuels94TA's Avatar
Re: what kind of 60' should i shoot for?
I've heard with nitto dr you can see 1.8 on up. This all depend on how the track is prep. I don't think sfc will help on your 60ft, there use more for road course racing to stiffen the car up. You want to avoid wheel hop off the line.
Old Oct 20, 2004 | 09:10 PM
MarkyMark's Avatar
2.3 is horrible......especially with drag radials. I would different pressures in your tires and do longer or shorter burnouts (change it up and see what works) You are either bogging bad or your spinning bad to get a 2.3 60'. Me personally I would shoot for a 1.95 or better 60 foot with your mods.
Old Oct 20, 2004 | 11:53 PM
i thought sfc's help traction all the way around the way a well set up high end sports car such as the vette would get better traction. and i am definately not spinning off the line with these tires on the track. i guess im just being too cautious trying not to break my rear end.
what is the best way to reduce wheel hop, because i was hopping pretty painfully at the 1-2 shift.
Old Oct 21, 2004 | 01:49 AM
Loony's Avatar
Some boxed LCA's with the poly bushings will help. I got to a 1.8 with my mini nittos so, you should be able to too...good luck
Old Oct 25, 2004 | 08:15 PM
Brit Iroc's Avatar
I run 2.3 '60ft times with G/Year eagles with stock pressures (30 psi). I was wondering what boxed LCA's and a new torque arm would do for me on the same tyres?. Want to keep on 'street' tyres for now.
Old Oct 26, 2004 | 01:53 AM
ScreamnChicken's Avatar
get lower control arms and relocation brackets. I have cut a best of 1.69 short time on 275 nittos. If you are not spinning, then try leaving at higher rpms until you do start spinning, then back off a couple hundred rpms.
I run my nittos at around 15psi and when I do my burnout I get my mph up to about 55 and hold it there for about 7 seconds to really heat them up.
Old Oct 26, 2004 | 08:04 AM
PatriotTA's Avatar
Nice short time for DRs, ScreamnChicken. My first time on DRs I was cutting 1.94 60s pretty consistently. Thats not bad, except for the fact that I have 4.10s. The track prep was pretty bad - it was either bog or spin. If you are at a track that doesn't have very good track prep, line up right behind a car with big meats. Then you can follow his trail of rubber and that might help you a little.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
Hal Fisher
Sep 30, 2015 09:03 PM
karpetcm
Sep 29, 2015 10:08 AM
