Went 11.67/120.... Want more!
Old Jul 24, 2005 | 02:38 PM
Kiddi's Avatar
Hi, Hi.. To begin with here's my time slip:
1.715 60 ft
95.34 mid mph
7.497 660
120.32 mph
11.678 ET
I've got '97 383 M6 Trans Am... 12 bolt and 4.10 gears. Stock heads, ported to 260/230 at .600 lift and custom roller cam that's at .603/.608 lift and duration at .050 at 230°/236 with 112 ls. and the compression ratio is about 10.8.
I ran it with centerline autodrag rims and 26x9x15 Hoosier slicks.
Now here's my suspension I've got boxed lower control arms, relocating brackets and boxed panhard bar, air bags and thats it...
What should I see in improvement by adding some nice torque arm (the short one from Sphon? (spelling)) and some other things I could add in......
Here's a picture
http://www.kvartmila.is/spjall/files/dsc06157.jpg
Old Jul 24, 2005 | 02:42 PM
Bow94z's Avatar
Re: Went 11.67/120.... Want more!
spray that beyatch!
Old Jul 24, 2005 | 03:02 PM
Stephen 87 IROC's Avatar
The need for speed. No matter how fast you run, you'll always want to go faster. The only cure is to spend more money.
I'm at the bottom end of a 10 second pass and I really want that 9 second timeslip!
Old Jul 24, 2005 | 05:03 PM
Kiddi's Avatar
Yeahh I know what you guys are talking about....... It's just that my 60 ft. suck, I want to see some low 1.6's damn it
Old Jul 25, 2005 | 06:23 PM
T/A lt1's Avatar
Well 120mph is good for low 11's. My car ran 11.20@120mph with a 1.58 60' that should have been better but I only have 3.42 gears in the rear and little ole 355" LT1. Goodluck. Later Clint
Old Jul 26, 2005 | 11:35 AM
94irocz's Avatar
I'll agree with that. I went 11.2 at 121 with a 1.57 60'. Stock 350 and 3.42's on a 150 shot. Have you tried different tire presures etc.? I have an auto and run on 15" mt street radials. How old are those tires?
Old Jul 26, 2005 | 04:55 PM
mattbailey's Avatar
Man thats smokin!! You've got plenty more in her, I'd look into some QA1's and an adj TA. They will get you that 60' you want.
Old Jul 26, 2005 | 08:39 PM
magnumv8's Avatar
what rpm are you launching at? Are you getting traction?
I have only had mine out once, but I launched at 5500 rpm and got a 1.60 60' that was with 28x9x15 slicks, qa1's, spohn t/a, 4.11's
You definately have something to gain in the 60'
Old Jul 27, 2005 | 04:54 AM
Kiddi's Avatar
Hi agian...
The tires are brand new Hoosier slicks... I tried tire pressures from 13-18 psi (cold).... It did'nt hook until I got it down to about 13-14 psi cold.
I definately will be looking into buying an adjustable torque arm... QA1's comes after that we're talking about money here, guys
My fastest pass was 120.9mph BTW......
