Two-Step w/ six speed
Old Nov 18, 2003 | 10:51 AM
  #16
Ponyhntr's Avatar
95Bird-
Let us know when you get that up on your site, I would like to take a look at it also. Thanks!
Old Nov 18, 2003 | 12:36 PM
  #17
Serene's Avatar
Originally posted by quick91rs
Another thing I just thought of for the N2O crowd. You could wire a relay into this to activate your N2O when the car leaves. You can get relays that have both normally open and normally closed contacts. In other words, the relay will also turn things on when de-energized and off when energized. When the 2-step turns off, the relay will turn on the nitrous. ARC makes a small time delay that could also be used to delay the nitrous hit from .1 to 1 second after the leave. Jeg's has them for about $35.
Way ahead of ya man
sending it to you in a sec 95bird
Old Nov 18, 2003 | 12:47 PM
  #18
Serene's Avatar
95bird i sent you the updated pic, had to fix some stuff on it
Old Nov 18, 2003 | 12:52 PM
  #19
95Bird's Avatar
here ya go guys
two step
**** updated to the latest setup sent.
Old Nov 18, 2003 | 05:53 PM
  #20
TravisA's Avatar
Thanks for all the help guys.
Travis
Old Nov 23, 2003 | 03:12 PM
  #21
Camaro_Guru16NY's Avatar
Definaely a cool little set up. I want one. IN the end how hard is it to wire everything together.
Later,
-JohN
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
njspder
Middle Atlantic
Mar 5, 2015 05:39 AM
sdn1997rs
Dec 30, 2014 08:30 AM
