track slip please advise
Old Jul 2, 2003 | 10:12 PM
clownhair's Avatar
went to the track again. i am still not happy my first time out I was running 14.1 all my runs today were 14.2x please look and help me out
I was launching at 3000 rpms but the car felt like it was boggin, I took it to 3500 and spun like crazy I then lowered to 3200 and spun again. maybe I am not warming my tires up good enough? I am running NITTOS set at 19psi and my 60ft is only slightly better than with street tires 2.2 vs 2.1
heres my best slip
r/t .909
60 2.160
330 6.061
1/8 9.216
mph 78.13
1000 11.923
1/4 14.208
mph 98.61
I was powershifting at about 6,000 rpms like I said I launched at 3,000 rpms and just side stepped the clutch
Advise please
Old Jul 3, 2003 | 12:03 AM
Antz97ZNJ's Avatar
The car will be in the high 13's w/ a 1.9 60...try babyint it outta the whole..then nailin her
Old Jul 3, 2003 | 06:54 PM
94GrayV6's Avatar
Is the car completely stock? If so, then you're doing about what you should be. Don't sweat it.
Edit: Just read your other thread again. Borla and free mods. Your car is fine, you just need more mods. Go for some Jet-Hot LTs . That should put ya at 13.7ish with the same 60' times.
Old Jul 3, 2003 | 07:31 PM
AL SS590 M6's Avatar
Moderator
What track are you running at?
Old Jul 3, 2003 | 10:42 PM
clownhair's Avatar
was running at stanton the only reason I am getting perturbed is I ran 14.1 before the Drag Radials
Old Jul 4, 2003 | 08:43 AM
5SPDCHK's Avatar
Was there a change in the weather (temp, AA, humidity) or track conditions... that can effect your runs.
Old Jul 4, 2003 | 09:41 AM
clownhair's Avatar
it was about 20 degrees hotter the second time and humidity was about 60%. Would this make the difference even though the 60 ft was better and the MPH was the same?
Old Jul 4, 2003 | 09:58 AM
94GrayV6's Avatar
Yep. Your car will run better in cooler, drier weather.
Old Jul 5, 2003 | 01:57 PM
96LT14u2Nv's Avatar
weather played a big part in it. also, try lowering the air pressure in those tires a little (like 12-15 psi)
with a good 60', u have a high 13 sec car
Louey
Pacific
Aug 25, 2015 01:53 AM
Louey
Pacific
Aug 7, 2015 01:47 AM
Louey
Pacific
Jul 27, 2015 09:58 PM
Jul 17, 2015 02:47 PM
