track results
track results
I made it to the track sunday and was not too happy when I left. My best pass looks like this-
r/t .188
60. 2.087
330. 5.789
1/8. 8.842
mph. 81.00
1000. 11.472
1/4. 13.68
mph. 102.06
The car has the mods in the sig. minus the subframes because there are not on yet. but the car has little bs mods like a airfoil, 1le elbow, 160 thermo, tb bypass, maf screen, fan switch. But this is the real kicker, I took out the back seat, front ps seat, front sway bar, jack&spare, mats. I weighted in at 3200 without me in it. I am only 170. So a 3370 raceweight and a 13.6 is all I could come up with. All the other passes I made were 13.8's on 2.1 60's. I thought I would of been good for a 13.5, especially when I saw my car on the scale. I also took off the stb. passes made on 245/50/16 yokohama avs es 100 tires
r/t .188
60. 2.087
330. 5.789
1/8. 8.842
mph. 81.00
1000. 11.472
1/4. 13.68
mph. 102.06
Re: track results
first time at the track with mine looked like this and i've only spent about 1000.00
rt .554
60ft 2.241
330ft 6.262
1/8et 9.501
1/8mph 76.37
1/4et 14.612
1/4mph 94.76
that was on dunlop street tires with a 327 and a auto with 342 gears
18 degrees temp no traction
rt .554
60ft 2.241
330ft 6.262
1/8et 9.501
1/8mph 76.37
1/4et 14.612
1/4mph 94.76
Re: track results
Within reason, the ET matches the MPH.
Ya, you can probably get a 13.5 or maybe even a 13.4x out of it. There are many variables when actually quantifying performance.
As a bracket racer myself I really utilize the little TAG weather station I have.
Temperature, Humidity, and Barometric Pressure combine to give me a DA. Over the couse of a normal day racing my ET will vary by .10 to .15 typically and I can dial the car accordingly. I also have to take into account day/night/cloud cover, wind, track conditions, and engine/tranny temperature.
Your 102 indicates to me that you can go a bit quicker. Back when I was running 13.6's I was normally at 100-101 mph.
Is your car an automatic or a standard? If it is a standard you can probably pick up so ET simply by working on your shifting technique and shift points. Also, a sub 2.0 sixty foot will help with ET.
If you went on a street night and had to struggle for traction, you should try a test and tune day or a race day when most facilities usually take more care in preparing the launch pad.
Re: track results
I was at the track in the middle of the day and I live in IL so it is humid here. But I thought after the after all the stuff I have done and the raceweight that I would of ended up with a better time. stock I went 13.97 on a 2.12 60ft. The track prep was pretty good that day.
Re: track results
Most recent track results turned up
R/T .278
60' 2.017
330' 5.508
660' 8.374
MPH 85.90
1000' 10.839
1/4 12.878
MPH 111.51
on worn street tires, SI with bolt ons,pump gas, full weight and 4.11 gears
R/T .278
60' 2.017
330' 5.508
660' 8.374
MPH 85.90
1000' 10.839
1/4 12.878
MPH 111.51
Re: track results
R/T .278
60' 2.017
330' 5.508
660' 8.374
MPH 85.90
1000' 10.839
1/4 12.878
MPH 111.51
R/T .278
60' 2.017
330' 5.508
660' 8.374
MPH 85.90
1000' 10.839
1/4 12.878
MPH 111.51
Anyways, I think your times are about right on. With some sticky tires you should be able to cut a few tenths off at least. Another thing you may wanna try is an exhaust cutout, I have one on mine and I can definately feel the difference. As others have said weather can play a big role, if you really want to see what your cars potential is then you will have to wait for a nice fall day with a low temp and low humidity.
Re: track results
Went back to the track last night, I only ran a 13.7 @102. But I trapped 103 on a 14.0 and a 13.9 so I know there is potential. I am getting a set of nittos drag radials and then I want to see what I will run. I think if I can cut a 1.8 60. I will be in the 13.4,13.3 range? or I am off with that guess?
Re: track results
I think you are right on thinking 13.3-13.4......I have basically the same mods as you do, but I have longtube headers and I ran the time in sig a few weeks ago. I am gonna go to the track on another day and ice the intake and (might) pull the belt off and see if it will run a solid 12.9 @106.xx. I also have a little weight reduction which helps, and you might wanna look into that. You will love having drag radials though, its a whole different ballgame when you can actually hook up outta the hole. I suggest the M/T Drag radials (but only if you are gonna mount on seperate rims that are not daily driven).
Re: track results
r/t .188
60. 2.087
330. 5.789
1/8. 8.842
mph. 81.00
1000. 11.472
1/4. 13.68
mph. 102.06
r/t .188
60. 2.087
330. 5.789
1/8. 8.842
mph. 81.00
1000. 11.472
1/4. 13.68
mph. 102.06
realistically the best u will prob do is a 1.9 60 foot, and that will bring your E.T. down to the 13.40's.
all in all with your race weight and your mods, i am not impressed. ditch the yok's and get some drag slicks.
Re: track results
r/t .188
60. 2.087
330. 5.789
1/8. 8.842
mph. 81.00
1000. 11.472
1/4. 13.68
mph. 102.06
r/t .188
60. 2.087
330. 5.789
1/8. 8.842
mph. 81.00
1000. 11.472
1/4. 13.68
mph. 102.06
Re: track results
Moroso intake, flowmaster AI 3 inch. I know that the flowmaster sux, I bought a hooker aerochamber to gain some more flow. I know no one is going to be impressed with my times, I think they suck too. I was looking for help/advice to why I am not running better times. As far as power all the mods are in my sig. and I listed the little bs mods in my first post. I would guess if your using stock m6 lt1 dynos(245-255rwhp) I would say I have 15-17hp from the intake/exhaust and maybe 5-6hp from free mods, little stuff. So I would maybe put down 270-275rwhp, I don't really know.
