tips on installing roll cage
Old Mar 17, 2004 | 08:28 PM
96_LT1's Avatar
i just bought a 6 point wolfe cage with the jig notch option and the subframe bars to make it 8 point. you guys have any tips on prep and installation? i'm having a buddy do the welding so i need to know any pointers on prep and measuring. the interior is all out except for those wires all over the floor boards.
Old Mar 18, 2004 | 03:06 PM
4mulaJoe's Avatar
You've got it easy b/c you bought it all jig notched. A few tips. Use a bench grinder to finish up the notching if it isn't perfect. Weld one side of the plate down first. Then hammer the rest to fit flush with the floorboard. Other than that you just mock it up and weld. The cutting a notching is the hard part. You want everything within an inch of the roof, doors, etc.
Old Mar 18, 2004 | 11:44 PM
Daryn95Z's Avatar
Watch out for FUEL lines!
Old Mar 19, 2004 | 08:10 AM
96_LT1's Avatar
thanks for the tips....i'll be sure to watch for fuel lines!! how much hammering is involved to get the plates to square up to the floor??
Old Mar 19, 2004 | 08:45 AM
4mulaJoe's Avatar
Well they are 6.125" square plates. There aren't many placeson the floorboard that are flat that much. It's not hard. Just have to hammer the edge untill it's close to the floorboard.
Old Mar 19, 2004 | 03:08 PM
red's Avatar
red
Make sure your friend takes the time to get the heat correct on some pratice material. The plates are thicker than the floor pan and it is real easy to burn through the floor if the heat if wrong. Also, make sure that your notches have no gap (or at least a little as possiable) for nice clean welds at the joints.
Old Mar 19, 2004 | 07:21 PM
sseeya's Avatar
Excellent advice! What gauge sheet metal is the floor pan? Anybody know.
Old Mar 19, 2004 | 08:22 PM
96_LT1's Avatar
thanks for all the tips guys. i'll post some pics when it's all said and done. i do have to wait 3 weeks for the cage though. speed inc. said there was a backlog on them.
Nov 18, 2023 07:21 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmyname1
Feb 19, 2015 08:38 PM
alex5366
Feb 17, 2015 09:07 AM
