times
Old Feb 13, 2006 | 12:04 PM
cbrakllr88's Avatar
times
What do you think an 01 camaro z with a heads/cam package from patriot performance.(.565. cam and heads unknown) a 3500 stall 4.10gears and a 200 shot could run? I know there are many factors but could I get a guesstimate?Thanks for the help.
Old Feb 13, 2006 | 01:02 PM
96m6lt1's Avatar
Re: times
should be able to run low 10s,possibly get into the 9s but as stated, factors prevail.
Old Feb 13, 2006 | 07:03 PM
The Engineer's Avatar
Re: times
Does it also have headers, proper PCM programming, suspension work along with slicks that will allow the car to launch? Horse power alone doesn’t make low ETs, it requires all components working together. Remember, 64% of your ¼ mile ET is made in the first 660 ft (1/8 mile), so if the car doesn’t launch well you will not realize its full potential. Running in the 10s consistently takes a “well built” race car and 9s for a full-body car is another issue completely.
Also, 11.49 to 11.00 requires a roll bar and 10.99 and below will require a 6 point cage if you're planning on being in the 10s.
Take it to the track and let us know what it does!
Old Feb 14, 2006 | 10:23 AM
95 FIREBIRD's Avatar
Re: times
1/8et times,stock automatic 95 firebird with street tires and et with drag radials?
Old Feb 14, 2006 | 02:16 PM
Re: times
For 1/8 mile times with a stock F-Body LT1 and ET DRs, I'll give you an ET range of 8.90 to 9.28. That would convert to 1/4 mile ETs of 13.90 to 14.50. Take it to the track and let me know how it does!
http://www.cardomain.com/ride/2189634
Old Feb 14, 2006 | 02:49 PM
Re: times
that would be great if i could turn those time with a stock car.my nova has a $4000. motor in it and it turns 9.00 with slipping tranny,2.73 gears.maybe the nova will get sold and put some nos on the firebird.opening day here in maine is april 29.i'll let you know how it goes.
Old May 10, 2006 | 09:25 AM
Re: times
the trans am ran 9.54 in the 1/8 with street tires.spun alot. my m/t drag radials will be here today.if it don't rain friday i can see what it does with traction.hope it's in the 8,s
Old May 11, 2006 | 08:08 AM
AL SS590 M6's Avatar
Moderator
Re: times
I know that this is an old thread but I still feel the need to clarify this statement.
There is an exception to the cage rule and it states: "if it's a full bodied car (not a 'vert) with the floorpan, body, and firewall un-modified then a 6 point rollbar is ok down to 10.00. pg 21 2006 NHRA rulebook. pg 105 2006 IHRA rulebook.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
