Those with ET Street Radials
Old Apr 20, 2005 | 08:10 PM
n2oCamaro's Avatar
I just got a set of these. What kind of burn out on are putting them and how low can you safetly go on the psi.
Old Apr 20, 2005 | 11:08 PM
T/A lt1's Avatar
Re: Those with ET Street Radials
I just put a set on my T/A and I am still geting used to them but I do a good 20-30sec. burnout and have run air pressure from 20psi all the way down to 15psi. w/o much difference. Another guy told me they are running 13 with good results with a low 10sec.ride like myself. I plan on trying that too but start off high 19-20 and work your way down unless they hook then leave them alone b/c the higher the pressure the better. Later
Old Apr 21, 2005 | 12:25 AM
Turbo6's Avatar
30 sec, are you sure? You would only get 4-5 passes out of a set of tires with that long of a burn out I would think. Usually 8-10 seconds is all you need, burn the water off, heat the rubber.
Old Apr 21, 2005 | 12:15 PM
morrowss's Avatar
Personally i only let them heat up about 5 seconds after i get some white smoke then push in the clutch and let the car roll out of it and they hook really good. I usually run about 12-13 lbs in them.
Old Apr 21, 2005 | 04:57 PM
T/A lt1's Avatar
Maybe not 30sec. probably 15-20 but I already have over 20passes and about 200 hard street miles and they still look like new. Later
Louey
Pacific
Oct 1, 2015 12:37 AM
HAWG
Sep 25, 2015 11:41 AM
pepon214tx
Sep 20, 2015 04:48 PM
DelSoto
Sep 19, 2015 05:31 AM
