Terrible Run...
Old Oct 28, 2004 | 10:25 PM
99BlackTA's Avatar
Terrible Run...
Tonight was the first night I got my T/A out on the track and only got to do one pass. It is a terrible pass but just curious what yall think I could get out of it with a REAL 60 foot! Here is my timeslip....
R/T=.765
60'=2.727
330=6.608
1/8=9.710
MPH=79.58
1000-12.390
1/4=14.678
MPH=98.71
Old Oct 29, 2004 | 12:37 AM
Javier97Z28's Avatar
Moderator
Re: Terrible Run...
With 98 mph and given that you were probably spinning quite a bit, I'd say you could pull a 13.8'ish
Old Oct 29, 2004 | 08:41 AM
kingman109's Avatar
Re: Terrible Run...
wow and i thought my 60' was bad (in sig)
if it makes u feel better the slip in my sig is my best out of about 8 runs... tractions a bitch with 18's and inexperience
Old Oct 29, 2004 | 09:27 AM
99BlackTA's Avatar
Re: Terrible Run...
I read that each .1 you get off your 60 foot equals to .2 of your E/T. Is that true? If so I should be pulling very low 13's.
PS: Last night was my first and only run ever in this car at the track. I will try some more for the last time next week.
Old Oct 29, 2004 | 09:49 AM
kingman109's Avatar
Re: Terrible Run...
very roughly and in ideal situations- i would say its more commonly .1 = .1-.15 but again u really cant predict by that alone-
i think that with ur times u should be pulling about a 13.6-13.8
Old Oct 29, 2004 | 05:13 PM
psychocabbage's Avatar
Re: Terrible Run...
How did you launch this car? what did you do from the point where you staged to the point where you crossed the line.
Did you do a burnout?
what kind of tires are on there?
did you go around the water box?
When were you shifting? If its an auto, what gear was it in?
Did you try and stall?
all this helps in determining how you drove it.. and what it may be capable of.
Old Oct 29, 2004 | 05:47 PM
99BlackTA's Avatar
Re: Terrible Run...
Well from racing before on the street I have tried stalling it up and that killed me. Then I tried from a dead stop punch and that was almost as bad as stalling. Then I rolled a little off the line and hit it and they gave me the best results so that is what I tried here but I guess I cruised way too long before the punch. I have Eagle F1's on the rear and it is an auto. Shifts right around 6k I believe.
Old Oct 29, 2004 | 08:07 PM
AL SS590 M6's Avatar
Moderator
Re: Terrible Run...
Rolling out street tires takes a lot of practice. When I (rarely) play on street tires at the track. I stall it up as much as it will hold, let off the brake on the 3rd yellow, and roll the gas pedal down slowly about 8 to 10 feet out and finally getting it to the floor right at the top of first. Netting 2.0x 60s and low 12s in my 11.5 second car.
Old Oct 29, 2004 | 09:11 PM
MarkyMark's Avatar
Re: Terrible Run...
you dont wanna roll out for very long.....really just to avoid the shock of going full throttle off the bat, and then you gotta get on it. A 2.7 60 foot is like a honda civic 60 foot........usually bad 60 foots in a fbod are in the 2.3-2.4 range at worst, so something definately went wrong.
Old Nov 5, 2004 | 03:39 PM
BaddAss93TA's Avatar
Re: Terrible Run...
just stomp on it and you will get better 60fts. lol.. i just straight out stood on the gas as soon as the light when and i ran a 2.3... witl little practice i got that down to a 2.01
Old Nov 5, 2004 | 03:55 PM
99BlackTA's Avatar
Re: Terrible Run...
*UPDATE*
Ran last night missing on #5 cylinder and a crushed tailpipe choking the car to death and ended up pulling a consistent 13.8 after a week of practice.
Old Nov 5, 2004 | 04:59 PM
ScreamnChicken's Avatar
Re: Terrible Run...
*UPDATE*
Get those problems fixed up and you should be 13.6 easy, if not faster. What were you're trap speeds and 60 foots?
Old Nov 5, 2004 | 05:06 PM
99BlackTA's Avatar
Re: Terrible Run...
best trap=102.7
best 60=2.084
Old Nov 5, 2004 | 05:31 PM
Re: Terrible Run...
best trap=102.7
best 60=2.084
Much better! With that trap speed you could go 13.5-13.4
FredM
Exhaust System
Feb 8, 2016 02:10 PM
Ks0209
Oct 1, 2015 07:32 AM
DelSoto
Sep 19, 2015 05:31 AM
MDZ28
Sep 7, 2015 09:16 PM
Devinfoote87
Sep 4, 2015 05:52 PM
