Tell me about my 1/4 times- Convertible
Old Nov 14, 2003 | 01:13 PM
BLUETOPTA's Avatar
Ok my car is a 1995 Trans Am CONVERTIBLE A4 LT1
my best et was 13.2
best MPH was 107
best 60' was 1.9
worst 60 was 2.2
* I ran a 13.1 once but i did redlight*
My car has the STOCK cam, nicely ported & polised heads and Intake, 11:2 compression, 2700 stall,3.73's, built trans, unbaffled ws6 ram air, slp headers, loudmouth exhaust, 52mm tb, ported maf, 1.6 rr, and all the little bolt ons and free mods.... oh yea and HYPERCRAP tunning.
For suspension I have BMR SFC's, LCA's, v6 rear springs, poly trans and tourqe arm bushings and no front sway bar.
I have 275/40/17 BFG KD's in the rear wich i put down to 20 psi and i did do small burn outs on the box. Thoes tires hook pretty good on the street but at the track i was spinning badly.
weather was about 65* and the runs were made at lapeet dragway.
So Vetran drag racers how do u think my times meet up w my car and what do u think it will take me to get in the 12's??????
Thx
Old Nov 14, 2003 | 04:44 PM
AutoRoc's Avatar
Redlight means NOTHING! Your time was still a 13.1. The clock that record your ET start when you move and end at the end. Once the yellow bulbs are lit you can go anytime you want really. On the yellows, once it's red, etc, your Et will be whatever you run. Your reaction time will be affected in some way but not the 1/4 mile time. Sounds like it runs very well, even on those tires. 20 PSi MIGHT be too low for them, not allowing the center of the tire to use it's tread effectively. 12's next time out maybe with some better tires! A stickier track might get you into the 12's even with those KD's. Every .10 reduction in the first 60 feet usually translates to a reduction of .15-.2 in the whole 1/4 mile so more traction is a MUST HAVE asap. Goodluck!
Is Lapeer seriously open until it snows?
Old Nov 15, 2003 | 10:56 AM
BLUETOPTA's Avatar
Thx AutoRoc, yea Lapeer is open till it snows. Thoes runs were made at the end of september...... I mite try to go b4 it does snow again.
Anybody else have anything to say about my times???
Old Nov 18, 2003 | 01:37 AM
MBonZ28's Avatar
this is what i did...take it for what its worth
97 Z28 M6
Hooker LTs
Full Length True Duals
SLP CAI
March Underdrive Pulley
Mez WP
MSD Dig 6
160 stat
Air foil
susp mods:
front sway bar delete
weight reduction:
!carpet
!back seat
!jack and spare
Weld Prs Stars with 27'' Hoosier QTPs
13.0@106 MPH w/1.9 60'
car made 293hp on a Dynojet and I think 278 or so on a Mustang Dyno
zFrank
Aug 12, 2015 03:46 AM
jbert55
Aug 3, 2015 05:49 PM
detroitmuscle
Jul 31, 2015 04:21 AM
ricks95TA
Jul 23, 2015 12:59 AM
ricks95TA
Jul 22, 2015 10:15 PM
