sway bar
Old May 29, 2006 | 07:21 PM
ss97dml's Avatar
sway bar
pro/cons of taking front sway bar off for racing? is it still drivable on the street or just take it off for racing?
Old May 30, 2006 | 02:56 AM
mccullar_racing's Avatar
Re: sway bar
I have never had any problems after taking the front sway bar off but i dont hit the curves, I just drag race. If you are going to do much high speed cornering I wouldn't reccomend taking it off.
Old May 30, 2006 | 04:42 PM
ss97dml's Avatar
Re: sway bar
just racing,joy rides and car shows.i could care less about cornering,so will it be all right to drive on the street?
Old May 30, 2006 | 05:09 PM
big dave's Avatar
Re: sway bar
it does make the car pretty sloppy in corners but it does wonders for helping the car launch.
Old May 30, 2006 | 07:42 PM
ss97dml's Avatar
Re: sway bar
how about city driving? i don't want to keep taking it on and off.
Old May 31, 2006 | 01:42 AM
Re: sway bar
You wont have any problems.
Old May 31, 2006 | 05:58 PM
Soccerbum21's Avatar
Re: sway bar
it gave me 2 tenths on my 60' when i unhooked the end link on the drivers side
it is a bit floppy on initial turn-in, but its not bad.
its so easy to unhook just the endlink you can do it at the track after you change your tires.
i just leave mine unhooked bc i'm lazy
Old Jun 1, 2006 | 12:41 AM
revtime's Avatar
Re: sway bar
I took just the sway bar off to see how it would feel, a week later I yanked the mounting brackets off and tossed em because I was never putting the sway bar back on.
I run on skinnys and I don,t have power steering so I take turns real slow and then as soon as its straight I hammer it.
you won,t have any problems running without the front swaybar, a couple of weeks and you won,t even miss it.
Old Jun 2, 2006 | 03:47 PM
tfs95z28's Avatar
Re: sway bar
doesnt it knock around under there with only one side unbolted? That cant be safe can it? LOL
Old Jun 2, 2006 | 04:14 PM
detroit1994z28's Avatar
Re: sway bar
I was also thinking about removing mine. All I want to know basically is will you notice a difference in the speed/launch??? I'm running 15x3.5" up front also. I will take it off if there's a noticable improvement?
Old Jun 4, 2006 | 08:04 PM
ss97dml's Avatar
Re: sway bar
took it off and it feels fine let's see if there's any difference at the track
Old Jun 6, 2006 | 08:05 PM
cammedss's Avatar
Re: sway bar
I have mine off also and the the only time i notice mine is if i brake hard in corners.
Old Jun 7, 2006 | 02:24 PM
Blue96z28's Avatar
Re: sway bar
you serious about the 2 tenths? is it really that big of a difference?
Old Jun 7, 2006 | 04:33 PM
Jameslt1TA's Avatar
Re: sway bar
took mine off...drives fine with street tires, but with et streets on the back corners are pretty hairy.
Old Jun 8, 2006 | 07:18 AM
ss97dml's Avatar
Re: sway bar
[QUOTE=Blue96z28]you serious about the 2 tenths? is it really that big of a difference?[/QUOTEwent to the track last night and taking off the sway bar DID NOT help at all.i can't figure it out,i took off the sway bar and my abs system,spare tire and still same times?
