Suspension questions????
Old Dec 29, 2003 | 09:48 PM
nd4spd200's Avatar
Does anyone have pics of frontend travel limiters installed on an f-body?? Just want to see how the look and work, i have made my own in the oast just lookin to see if i can make these or if i have to buy them... Also, what kind of pinion angle are you guys runnin?? i run 3.5 degrees without me in the car.. my best times are in the sigs.. just tryin to get an edge on suspension setups... thanks in advance....
Old Dec 29, 2003 | 11:06 PM
Stephen 87 IROC's Avatar
Unless you're pulling big air like a Super Stock, you probably won't like the travel limiters. Letting the front end rise really helps with weight transfer. Cars that use travels limiters the most are Super Comp or Super Gas since they want the front end to stay down as much as possible.
3.5* should be fine.
Old Dec 30, 2003 | 04:22 PM
WS Sick's Avatar
I'm learning in the suspension dept as well, is the 3.5 negative?
Old Dec 30, 2003 | 05:16 PM
nd4spd200's Avatar
yes that is negative angle, so, anyone have any pics of limiters installed???
Old Dec 30, 2003 | 08:29 PM
I don't use them myself
Old Jan 2, 2004 | 10:44 AM
WS Sick's Avatar
Thanks, I have never used limiters as well (never needed them ).
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Hurin
Dec 13, 2014 07:38 PM
