Sprayed the nitrous finally! Now new issues
Old Jun 16, 2011 | 03:09 AM
96LT1TX's Avatar
60': 1.736
1/8: 7.512
MPH: 94.04
1/4: 11.564
MPH: 121.05
So it went ok, car ran great. Without the 100 shot it runs 12.1s@115 consistently so I guess I expected a little more out of the 100 shot. I guess I just need to actually hook one of these days. I did not mess with the airbag in the right rear, I bet I could have squeezed a better launch out of it. I really need help answering question 2 below!
Basically now I have 2 problems:
1- A slight oil leak is growing that I keep trying to find but I am afraid it may need to be reckoned with. When the car is hot like really hot it causes like 2-3 drips after sitting for a while. I tightened the oil pan but this did nothing. I am afraid that the stock pan needs to go due to not sealing now with the increased crank case pressure. Maybe a breather would help?
2- I am now going through the traps at roughly 6200-6300 rpms when I usually shift right around 6000-6100rpms. I could not get up the courage on any of my runs to switch into 5th and I dont think that would be a good idea. What do you guys think? The way I see it, I could go to a smaller tire, switch into 5th, spray a 150 shot and go into 5th or change the gears. I have liked the 4.10s for a long time (like 7 years now) but now that my trap is 120s something needs to change. I spray 3000-6000, max HP is at roughly 5500 rpms. Every time I try and shift earlier though my times are slower.
Please help me on the shifting issue!!
Old Jun 16, 2011 | 06:08 AM
AL SS590 M6's Avatar
Moderator
Re: Sprayed the nitrous finally! Now new issues
Just go with a slightly talller tire and run it thru in 4th.
Old Jun 16, 2011 | 06:25 PM
96LT1TX's Avatar
I have the 26.5's and the 27s wont fit for some reason under my wheel well. Any way to make it fit?
Old Jun 16, 2011 | 07:04 PM
96LT1TX's Avatar
Also, what am I supposed to do when I bump the shot up? The 100 shot was just to wet the appetite 150 shot is next then 200 then 250.
Old Jun 17, 2011 | 06:12 AM
Moderator
What is your tire/wheel combo?
Old Jun 17, 2011 | 08:49 AM
AutoRoc's Avatar
Sounds fine to me. Less gear or taller tire will make it accelerate slower. Over reving it isn't hurting your ET at all. You have max effort gearing and a few more mph/rpm won't hurt it. That's a solid rotting assembly that is probably safe to 8000 rpm.
Working on more hook is what you need. Launch rpm, maybe a 2 step rev limiter, air hag, tq ARM changes.
If you have traction problems, you should delay the nitrous a few tenths of a second.
If its bogging, you should leave off a 2 step with the nitrous flowing before the clutch even drops.
Goodluck, you 6 speed guys are hard on parts!
Old Jun 17, 2011 | 09:49 PM
96LT1TX's Avatar
AutoRoc,
I just need more reps with it and to start using my 2step. I have a 2 step setup I just never use it. The best launch of the night was a bog... so I need to get the launch dialed in for sure. I have hit a 1.68 before but a 1.45 would really give me some good times. Since I have the moser 12bolt I need to get a weld in LCA relocation brackets really to improve it and mess with the tire pressure/air bag pressure until it actually hooks.
I have the Hoosier 26.5x15x11.5s on some IROC Z 15x9s? and that is probably why it wont hook. Some good 15x11.5 rims with the 11.5 tire would help a lot. I think that and some skinnies are next... I just dont want to have a thinner tire in the back than in the front (stock 17x275s).
Old Sep 9, 2011 | 01:15 PM
LT1TONY's Avatar
Rev it higher if you can and have forged internals or go to a bigger tire.
I run a 28x10.5.15 ET Drag and have much better success with a Drag tire than ET Street. I also run 4:10 gears.
To run that tire you will have to cut your bumper by the wheel well opening and move it back to allow for more room. I did that and regraphed the piece back onto the bumper and repainted the bumper so it looks stock and you can't tell a thing. Might have to pound the front inner part of the wheel well too.
Old Sep 10, 2011 | 06:25 AM
15x10" wheel, 7.5" backspace. I ran a Hoosier QTP 28x11.5-15 and only adjustment needed was to move the axle assembly back about 1/4" with adjustable LCA's. The inner fenders had already been hammered for 315's. Currently running 28x10.5-15W ET Drags and the only change was to take about an inch off the leading edge of the bumper cover.
Check the drag tire FAQ on the "Wheel & Tire" forum.
As far as shifting, try it. I run a TH400 with a Gear Vendor O/D. With a 7,000RPM redline, the 28.1" slick and 4.11 gears it needs to shift into O/D at about 136MPH. The GV does shift instantaneously though.
C6LS3
Apr 15, 2015 09:50 AM
bandit383lt4
Dec 21, 2014 09:12 PM
madman69
Aug 18, 2002 03:58 PM
Dragonballz28
Jul 25, 2002 03:19 PM
