Some serious traction help needed
Old Apr 23, 2003 | 09:25 PM
Rice Killer87's Avatar
i have an 87 IROC-Z w/ a 350 and automatic. its not a posi rearend and not sure what the gear size is.
problem~car will spin all day from a dead stop,and will break traction when floored from about a 25 mph or so roll. yea,its cool and stuff,but when i want it to go,i want it to GO! u know,not roast the damn tires all day. it even spins at the track. it ran a 9.95@71 (letting off the gas to catch traction,and then back on again) in the 1/8 mile (i blew the head gasket that time also) and thats so slow b/c i cant nail it at all off the line.
solutions~? what can i do to help this problem w/o getting slicks. the tires i have now are 245-50-ZR16 BFGoodrich KDWS's. is there somethin i can do to the suspension or torque arm or anything to help it hook up? i would very much appreciate any help on this problem.
Old Apr 23, 2003 | 11:25 PM
LT1 1980 malibu's Avatar
1st off get some real tires..the KD series is nice to turn..Get some drag radials and you should hook fine.street radials will go up in a blaze no matter how much stuff you toss on the suspension
Old Apr 23, 2003 | 11:33 PM
94GrayV6's Avatar
You said it's not a posi? Well I dont know how that could have happened, but that's the first thing you should get. You can get one for around 100 bucks. The best tires in the world won't help you as much as a posi will.
Old Apr 24, 2003 | 08:14 PM
only 100 bux? where??
thanx to who responded
Old Apr 24, 2003 | 08:29 PM
RacinLT1's Avatar
SLP has take out posi's for around $100.check them out.
Old Apr 25, 2003 | 01:25 PM
thats cool,but if they are take out that means 4th gen. my car is a 3rd gen and its not a direct bolt up switch.
thanx
Old Apr 25, 2003 | 05:05 PM
10.90streetcar's Avatar
Yes you can make an Open rear hook. I had an 85 with 3.08 gears and an open rear. Dont remember the 60ft times but it would dead hook and run 13.85 in the 1/4. It had 275 60 15 BFG radial TA, Air bag in the pass. rear, no front sway bar and wore out front struts. It wasnt really my car, it was Video Chics Car
Old Apr 25, 2003 | 08:34 PM
rskrause's Avatar
Moderator
You need a posi. Call http://www.ring-pinion.com/ . It's "Randy's Ring and Pinion" and they know rear ends.
Rich Krause
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
