Slicks&Tubes And Balancing
You guys try and balance your slicks and tubes combinations? I had mine balanced this past week, the one tire/wheel/tube combo took over 10 oz's to get it to balance .. seems a bit excessive since after one burnout they'll be back out of balance..
--Sean
--Sean
I have mine balanced. I get them static balanced and use the stick on weights in the center of the rim. I then cover the weights with duct tape.
10 oz is a lot but I think mine are 5-6 oz.
If they go out of balance after a burnout then you have something else wrong. After I balance mine when I install new tires on the rims, they don't get balanced again until new tires are needed or the weights manage to fall off.
Re: Slicks&Tubes And Balancing
--Sean
--Sean
If it still takes 10 oz. there may be something else wrong.
