roll cage question
Old May 17, 2004 | 08:18 AM
96_LT1's Avatar
roll cage question
quick question for those that might know. i'm installing my wolfe cage, and it is pretty much done. i'm having trouble with the passenger side door. the arm rest on the door is just a little tighter than it should be and interferes with closing the door unless you force it. the driver side is perfect with no more room tp adjust. has anyone else run into this problem?? the bar is notched and scribed and has fit perfect except for the pass. door. my only thought was to maybe grind a touch off the arm rest or put a notch in it and then paint. any other ideas??
Old May 18, 2004 | 07:06 PM
MBonZ28's Avatar
hmm your hoop could be off, maybe try and get more bend in that door bar
Old May 18, 2004 | 11:52 PM
96_LT1's Avatar
apparently my hoop is a little off. i ordered the rear bars as installing on the sides instead of over the seat, now the driver side is off just enough to keep the hatch from closing because the strut interferes with the bar. everything is where it needs to be. maybe my car is crooked i guess i'll have to get the over the seat rear bars now. the door seems to close a little better now with a grove in the arm rest. oh well, such is life. it is a kick a$$ roll cage though.
RUENUF
Mar 13, 2016 03:39 PM
cmyname1
Feb 19, 2015 08:38 PM
Doug Harden
29
Jul 30, 2003 07:05 AM
T/A lt1
Oct 10, 2002 03:14 PM
Wolfe Race Craft
Sep 12, 2002 08:51 PM
