Pics of new rear Draglites.
Old Aug 23, 2002 | 10:25 AM
Ken95Z28's Avatar
Post Pics of new rear Draglites.
New Wheels and Tires Shot #1
Here is another one.
New Wheels and Tires Shot #2
Not to bad at all.
These are 15x10 Draglites, the tires are Hoosiers 26x10x15. They are screwed to the wheel and not running any tubes in them. I had to install longer wheels studs to get them to work.
1995 Z28 A4 3.42 Best ET(12.205@109.50) LT4 Hot Cam, 1.6RR's, K&N FIPK, 85mm MAF, Hooker LT's, Dual Exhaust, Yank ST3500, TransGo Kit, CSI WP, Hoosier Slicks, 6-point Wolfecraft and Ed Wright Programming
Ken's 1995 Z28
F-Body Fastest List
"Never be afraid to try something new. Remember that amateurs built the ark. Professionals built the Titanic."
Old Aug 23, 2002 | 11:23 AM
Grover's Avatar
Post
Looks good Ken!!
Did you have any problem with the wheel studs in the front being too short?
Chad Beebe
'97 T/A WS6 M6 Dark Metallic Green
CC 306 cam and some other stuff.
My Car
12.762@109.13 with 1.828 60'
Best 60' 1.816
Old Aug 23, 2002 | 11:38 AM
CANTONRACER's Avatar
Post
Looks really good.
How much did they weigh vs your previous tire/rim combo? Were you running stock before?
Have you gotten a new ET/MPH with your new tire/rim combo? If you have, how much did you lose if any?
Again, looks damn good.
1996 Z28 Camaro
2001 best 1/4 BFG DR's NA - 11.865@113.57 w/1.634 60', 1/8 - 7.563@89.82mph Best 1/4 MPH 114.82 - Best 1/8 MPH 90.73 - 2002 Mid 11's NA, Mid 10's n2o
1989 GMC 1500 truck for work 18.1@73 305
8 cats to feed clean after 1999 V6 Mustang 5 speed
15.358@89.47 MPH w/ 2.227 60'
15.364@90.92 MPH w/ 2.383 60'
My Z28
Old Aug 23, 2002 | 12:39 PM
Ken95Z28's Avatar
Post
Grover - The fronts got replaced as well, the stock ones are way to short.
The Draglites are about 15lbs for the wheel and about 16-17lbs for the tire. I had stock wheels with ET Streets mounted on them. That was about 40lbs or more for that setup. I use to have ZR1 front wheels on them a long time ago.
CantonRacer - So far with this setup I ran a best of 12.40@108, that's in 90 degree heat and somewhat low barometer and 70% humidity.
The best time is in my signature, thats on a very cool night high 50's to low 60's when that happened. I can't wait for the cooler weather.
At least it does not appear that I lost any MPH from the ET Streets to this tire. Not to sure on my 60' time yet, I will be going to the track next Friday to see the 60' times, but I suspect they are in the 1.7's right now.
Old Aug 23, 2002 | 01:43 PM
Wicked's Avatar
Post
My 15x10 Prostars w/ 28x13.5 Hoosher QTP's weighted in at 37lbs a tire. I was a little disappointed.
Car looks good man!
Jason
Plates: "Stock 95"
1995 Firebird Formula
O'ring/4bolt 383, GTP Race Ported AFR 210s, Yank TH400, Yank 3800 Stall, Trans Break, Moser 12 Bolt w/ 3.73s, and the usual stuff like Hooker Long Tubes, Holley 58mm TB, Sphon Torque Arm, etc....
Old Aug 23, 2002 | 06:04 PM
JG94Z's Avatar
Post
31 lbs for hoosier 28 11.5 with bogart rims.
here's the d10's mounted on a car.
http://www.haoleboyss.cz28.com/photo2.html
www.performancepartsoutlet.com is a distributor of these.
http://www.bluefirehawk.com/images/ppo/dsc00081.jpg
http://www.bluefirehawk.com/images/ppo/dsc00076.jpg
http://www.bluefirehawk.com/images/ppo/dsc00079.jpg
pics of fluted drag stars.
These are direct fit rims no spacer no grinding Stock studs will stick out 1/4 of an inch of hub with the bogarts.
1994 #8 Procharged Z28-M6, LT4 Hot Cam with 1.6 Crane Gold Race/AS&M Headers/AS&M 58mm TB/#30 Bosch/AFPR/Mezzerie Electric H20 Pump/Borla/RT High Flow Cat/4.10's.
Old Aug 23, 2002 | 06:42 PM
Stephen 87 IROC's Avatar
Post
I also run Hoosiers on Draglites without tubes. I marked the valve stem on the tire with some shoe polish. After about 30 or so runs the mark had moved about 2 inches from the stem. I've screwed the tire to the rim now. Since I don't have tubes there no chance of damaging a tube but if the tire slips that much it's going to start changing the balance.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.418
Best MPH on a time slip: 117.01
Best corrected ET: 11.051
Altitude corrected rear wheel HP: 468
Best 60 foot: 1.595
Member of the Calgary Drag Racing Association
Old Aug 23, 2002 | 07:59 PM
chevy94c's Avatar
Post
Ken
Did you have to do any other changes to get them to fit? I heard something about the calipers.
Old Aug 23, 2002 | 11:51 PM
Projectz28's Avatar
Moderator
Post
Ken, Looks good bro. I am going the exact same route with my wheel and tire combo. Can you give me more details about the studs? I alreay picked up a set of 15x3.5's for the front and am curently looking for a set of 15x10's for the rear. What size studs and lugs did you use? And where did you get them from? Id rather not try running that combo on stock studs if they are that much too short. Any info you can give would be greatly apreciated... oh and whats the BS on the rears and are you using a spacer or not?
Brian
96 Red z28, A4, Flowmaster, SLP CAI, AFPR, B&M transpack & cooler, LT4 KM, 3.73's, T/A girdle, LS1 driveshaft, cc305, Crane 1.6's, MSD 6AL, Meziere, ST3500, JetHot/Hooker LT's
The Project!!!
Best ET: 11.91 Best MPH: 113.54 Best 60': 1.59
327RWHP/380RWTQ
East Coast F-body Nats
It's god's responsibility to forgive Bin Laden, it's our responsibility to arrange the meeting...
-United States Marines
Old Aug 25, 2002 | 05:12 PM
Ken95Z28's Avatar
Post
Projectz28 - You have mail
Old Aug 25, 2002 | 07:08 PM
speedmiser's Avatar
Post
Looks nice Ken.
Here's mine.
http://images.cardomain.com/installs...70_47_full.jpg
Hey Wicked - Did you have fun clearancing the rear for the 28 x 13.5 Hoosiers? Took a lot of "Hammer Time", a jig saw, and sawzal to get mine to tuck under without slicing the 28 x 13.5 MT ET's
If I'm playin, I'm sprayin
93 Z28 A3 - w/ Jet Hot coated Hooker LT's and true 3" duals
(hiflow cats, cutouts, and Car Chemistry insert mufflers)
Old Aug 27, 2002 | 10:11 PM
Z4 Performance97's Avatar
Post
Hey what is the off-set for the 15x10's in the rear? For the first black z28
Old Aug 27, 2002 | 10:33 PM
Ken95Z28's Avatar
Post
7.5 for the offset.
Old Aug 28, 2002 | 09:47 AM
Nostang 96z's Avatar
Post
Could you let me know what size studs you used for the front and what lug nuts were used? Also, how many screws per wheel did you use?
Thanks for the info.
Matt
96 Camaro Z28 6spd., T-tops, custom viper red with pearlcoat paintjob, 355 LT1 11.5-1, GTP stage 2 LT4 heads/intake, GTP-6 cam, full cage, moser 9" with 4.11's, full suspension, and too much other stuff to list. Best so far after shakedown runs...still needs tuning and suspension tweaking.
1.754 60', 12.137@116.07, 7.848@90.53 1/8 mile
The Z under construction
92 Talon TSI 5spd. AWD Best E.T.-13.753@98.30mph
1.885 60ft.@13lbs boost--- For Sale!
Old Aug 28, 2002 | 12:52 PM
Ken95Z28's Avatar
Post
Stock stud size except longer.
Get the GM PN# 22551491 that should do the trick, ARP makes one that is not as long.
I used Welds Shank style lugnuts 12mmx1.5 open ended, this is the Jegs number 927-601-1422, sad thing is that they come 4 to a package.
I put on 8 screws per side of the wheel (16) total per wheel.
