Picked up some MT ET DR's, have a few ??'s
Old Sep 6, 2007 | 09:16 PM
BlackbirdWS6's Avatar
Just picked up a set of 255/50/16 MT ET DR's to go on my spare 16x8 rims. What psi is recommended for running these tires on the street and the track. I will be only throwing these on to go to and from the track. I was told many people typically run 21-24 psi in these tires at the track.
What rpm should I be looking to launch at with the stock 10-bolt in order to net me some decent 60's while attempting to not totally wreck the stock rear? I know going to the track with sticky tires and asking that question is kinda silly but I'm just looking to put down some better times and will go for the gold when I finally splurge on a 12 bolt. I have a spec stage 3 clutch if that is of any pertinent info and the mods are listed in my sig.
-Brian
Old Sep 6, 2007 | 09:30 PM
Z-RATED94's Avatar
The psi you stated has worked for me, 24lbs hot. As far as launching a stick, you are on your own with a ten bolt. Go easy and good luck.
Old Sep 10, 2007 | 07:51 AM
Geezer powered's Avatar
start at 18-19 cold and work your way down from there.
Old Sep 10, 2007 | 08:31 AM
AL SS590 M6's Avatar
Moderator
Most modern DRs work well with more air than that. And you want the most air in them that still allows good traction. Higher air pressures mean more stability and better top end mph. My Hoosier DRs dead hook 1.48s with 21 psi hot.
Old Sep 10, 2007 | 11:46 AM
Z-RATED94's Avatar
Well said. Next time out I'm going to bump up the air pressure a couple of pounds, and see if it still hooks.
Old Sep 10, 2007 | 08:34 PM
sn8ke eatr's Avatar
i can hear the 10 bolt breaking already...haha
on my old bfg dr's i ran them at 16psi but they were bead locked. im not sure if you should go that low if there not locked
Old Sep 10, 2007 | 09:26 PM
Z-RATED94's Avatar
Ran my Nitto's down to that (hot) with no problem. Didn't help any more than the 18 to 20 lbs. though. Only massive amounts of smoke in the water box seemed to help the best.
Old Sep 11, 2007 | 11:56 AM
CamaroRacing12's Avatar
same but with the et streets lol
Old Sep 12, 2007 | 05:02 PM
thanks for the tips guys...I'm going to say a little prayer for my 10-bolt before I go but I don't think it will matter
-Brian
Old Sep 12, 2007 | 08:30 PM
u spray off the line?
Old Sep 13, 2007 | 10:14 PM
sc68z28's Avatar
Originally Posted by BlackbirdWS6
What rpm should I be looking to launch at with the stock 10-bolt in order to net me some decent 60's while attempting to not totally wreck the stock rear? I have a spec stage 3 clutch if that is of any pertinent info and the mods are listed in my sig.
-Brian
Brian, IMHO, Try leaving soft, as low as possible without bogging the engine.
The drag radials will most likely spin some (something has to give) most likely the clutch wont slip and hopefully the 10 bolt stays together.
The problem you will have, is blowing the tires off.
Mickey Thompson does not usually recomend D/Rs on clutch cars, they did not work for me.
You could also try feathering the clutch out, thats not easy. I can't do it and it's very hard on a street type clutch. Thats what a good drag race clutch will do for you, slip a little (something has to give). I leave at 6K and the clutch slips for at least the first 25 feet. My rpm never goes under 5K.
Play with it, have fun, don't break anything and let us know how it goes.
---Bill.
Old Sep 14, 2007 | 12:06 AM
hey bill ur car is absolutley amazing... where did u get those seats? i have to bring a magazine article to class tomorrow and i think im gonna bring ur article lol
Old Sep 14, 2007 | 11:22 PM
sc68z28's Avatar
Thank you very much, yours is coming along nicely too.
My seats are just those Jegs $190. jobs. Warning they are heavy, 45lbs ea. http://www.jegs.com/webapp/wcs/store...0002_119490_-1
I have seen them recently at Kragen (CSK auto) for $150
---Bill.
Old Sep 15, 2007 | 12:54 AM
are they leather? o and thank you for the compliment... it means a lot from a guy like you
Old Sep 15, 2007 | 10:50 PM
sc68z28's Avatar
are they leather?
simulated leather, AKA vinyl, leatherette.
---Bill.
