ok my drag slip
Old Sep 9, 2007 | 08:53 PM
Z28_AJ's Avatar
ok my drag slip
i ran a 14.349 at 98.47 my 60ft was a 2.560 if i got my 60.ft down to a 2.0 what would i be running then..
Old Sep 9, 2007 | 09:02 PM
Z-RATED94's Avatar
13.50 to 13.60s, or somewhere close I would imagine. How do you launch that the 60ft. time is so bad? Was that your only run?
Old Sep 9, 2007 | 09:06 PM
Z28_AJ's Avatar
umm i just come up to the line and push the brake down and give it gas before the tires spin..i need tires too..
Old Sep 9, 2007 | 09:11 PM
Z-RATED94's Avatar
Well, until you get tires, how about slowly rolling into the gas? Or how about some MT street radials and a quality converter and go low 13s? That way you won't have to change your style of stomp the gas and hope for the best.
Old Sep 9, 2007 | 09:15 PM
Z28_AJ's Avatar
yeah i guess i'm going to have to buy me a set..
Old Sep 9, 2007 | 10:31 PM
northdakota93z28's Avatar
what was your 8th time
Old Sep 10, 2007 | 06:54 AM
Z28_AJ's Avatar
9.471 1/8
Old Sep 10, 2007 | 07:49 AM
Geezer powered's Avatar
I'd say you be running 13.90's to 14.00's with a 2.00 sixty foot. Cut a 1.8-1.9 and you'd be running 13.70's
Old Sep 10, 2007 | 08:07 AM
Z28_AJ's Avatar
nice i need some more mods and some mt
Old Sep 10, 2007 | 11:42 AM
Z-RATED94's Avatar
Rule of thumb is that for every .10 you cut of your 60ft. you will cut .15 off you et, if not more. Working on your 60 ft. time is one of the biggest bangs for the buck. Especially in your case.
Old Sep 10, 2007 | 11:44 AM
Z28_AJ's Avatar
thanks what the best things..mt tires,t arm,umm droping the car help too
Old Sep 11, 2007 | 04:37 AM
AL SS590 M6's Avatar
Moderator
First get some drag tires then worry about the suspension pieces.
Old Sep 11, 2007 | 01:35 PM
TedH's Avatar
Get some drag radials, and go to the track when it is being properly prepped. You should be in the 13.9 range. Add headers and you will be 13.5-13.6. At least that is where I was at with my '94 when I started out.
Old Sep 12, 2007 | 12:00 AM
CamaroRacing12's Avatar
Ted will i see u at chevyfest?
IndyZman
Oct 22, 2015 02:17 PM
HAWG
Sep 25, 2015 11:41 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
