Octane booster
If you are not having knock issues, any octane more than you need is a waste of money and ultimately may lead to slower times.
Now if you have poor quality gasoline, water, clogged injectors, or whatever, sometimes an additive can improve things regardless of what it says on the side of the can. I sometimes will put in a can of the el cheapo $1.29 boost if I need to fill up at a questionable service station.
Timing changes (higher), higher compression ratio, blown, turbo, N2O, by all means you will need more octane!! If STOCK in these areas, than NO! Actually higher octane gasolines and additives SLOW DOWN the burn rate for more controlled combustion.
HInk
HInk
Originally posted by WheelmanZ28
Don't foget, although those brands often advertise that they raise ur Octane levels by 3 or 4 points, if u actually read the whole label and study the affects, it's actually .3 to .4 points.
HInk
still in the can. As far as I know it doesn't like to be stored in clear conatiners. I'm using the same stuff from last year, in fact it's the free cans I got for selling to you all!!
Don't get it on your fingers or such as it does smell like HECK and won't come off for a few days!
But I'm sure you've experienced that before in one form or another!!
HInk
But I'm sure you've experienced that before in one form or another!!HInk
Aug 24, 2015 06:41 AM
whitehooptie
Jul 12, 2015 06:10 PM
