New setup!
I was running a hughes TH350/4000 TC that was less then optimized and ran a best of 6.68@100.5 mph in the 1/8 mile. I now have a PG with custon built converter for my setup, and was told by a friend of mine who runs IHRA crate motor stock, that with the correct converter the car should pickup .15.
As for the gear, yes it's alot but not for the 1/8 mile.
Randy
Randy
Good luck randy.
Converter is critical as you know...who is your crate stock buddy? Darren?
I ended up going to ATi for a converter....... I need alot mor carb than what I have. And every week it gets cooler I run out of jet.
But Mine has only been 1.44 with the 28" and a 4.56 I was hoping for more but I am out of h.p. car is dead hooking
Jr Riener is the C/M stocker. He hs a 96-97 camaro with a fast burn 385 hp 350 that runs 6.60's on the bumper.
I'm sure once you get the right size carb, I'd say about a 950, it will fly. I've seen as much as 2 tenths by going to a larger carb.
Randy
Randy
Thanks Sean, the car did run well with the th350, but the converter had over a 1000 passes on it and it was an off the shelf piece so I think there was more on the table. The new converter for the glide was built to my specs and is spragless. I'm hoping for 6.5's and once I get a FAST XFI and dial it in, who know's it might run 6.3's, but we'll see. I'll keep everyone posted.
Randy
Randy
Well I finally got to go to the track today. The weather was OK, but not great and I ran a 6.665 @ 100 mph. This was at a TnT so the track prep wasn't the greatest. I still think there are some 6.5's in it, I'll keep everyone posted.
Randy
Randy
I wont get rid of mine....I want a 2.75 gear set for mine and I will be in the 1.30's easy....I printed the same number 3 time today. 60' 660 and 1/4
The glide is roughly a tenth faster than the th350 in the same air. The th350 actually had slower 60fts, with more gear ratio, than the glide. If the car weighed less I could have used an aluminium high gear hub which would probably pick it up another .05, but I'm real happy with how it runs and on a bracket racing note I now only have to make one shift vs two and with less first gear ratio I won't have to worry as much about spinning the tires at marginal tracks.
Randy
Randy
detroitmuscle
Jul 31, 2015 04:21 AM
