New personal best
Old Sep 4, 2008 | 09:02 PM
94 Sunburst formula's Avatar
New personal best
I took my car to the test in tune in Muncie, In. My car is still running the stock tune and suspension except lca relocation brackets. Also I am running street tires BFG comp t/a with 24 lbs air pressure feathering my launches at 1500-2000 all the way through 1st then nail it.
2nd set of times is best not red lighted
r/t -.037 .487
60' 1.924 1.950
330 5.519 5.582
1/8 8.482 8.550
mph 83.21 83.25
1000 11.055 11.128
1/4 13.241 13.319
mph 103.53 103.24
Sucks my best run i red lighted, but correct me if i am wrong but a red lite run still is accurate time wise. Anyhow any suggustions as to a better et or any pointers at all?
Old Sep 5, 2008 | 01:21 AM
96m6lt1's Avatar
could use more info on the car:
Old Sep 5, 2008 | 01:25 AM
96m6lt1's Avatar
could use more info on the car:you need a tune BAADDDDD!!!!
gear etc. mph is on the low side but what other variables were against you?
Old Sep 5, 2008 | 09:01 AM
slomarao's Avatar
you need a tune, very badly.
Old Sep 5, 2008 | 09:57 AM
Its a built auto with as far as i know a stock geared ten bolt. I am going to be taking the cover off today and check what gears it has in it for sure. The only weight reduction i have done to it is ac is gone, air pump, spare tire and jack out, has a fiberglass ram air hood not funcunal dont know what kind it is was on the car when i bought it.
Old Sep 5, 2008 | 12:42 PM
3.42 gear ratio
cmsmith
Sep 14, 2015 09:09 PM
FryedClutch
Sep 1, 2015 08:24 AM
RobFlag
Aug 29, 2015 11:40 PM
WPHIG2
Aug 27, 2015 06:37 AM
Aug 17, 2015 09:50 AM
