New best! (video inside)
Old Sep 13, 2002 | 09:34 PM
RichJ's Avatar
Post New best! (video inside)
Improved my best time by over 2/10ths today. Happily I caught it on tape:
http://members.***.net/rjohnston11/new_best_1227.mpg
Previous best was a 12.48@110 (but I usually run 12.7s and 12.8s). Today I ran a 12.27@112, a 12.29@112 and a few 12.3s.
What changed? ET Streets vs. BFG DRs and better valvesprings. Oh...and today's best was in the middle of the afternoon (about 82 degrees) vs. the previous best set in the upper 40s. (Think I might be able to squeak an 11 with faster shifting and cooler weather?)
I'm really happy about the improvement. And my car can still easily pass IM240 emissions with the sniffer friendly 224/230/114 cam
RichJ
95z28 -- stock bottom end, heads/cam
Old Sep 13, 2002 | 10:35 PM
TravisA's Avatar
Thumbs up
Nice vid and congrats on the new best!
Whats your 60' on those runs? I could only manage high 11's @120-121 mph on my setup in 90+ weather. My 60's were only 1.90's. I think with the mph i should be mid to low 11's.
What kinda exhaust setup you running it sounds good.
Later
Travis
[This message has been edited by TravProcharged94Z (edited September 13, 2002).]
Old Sep 14, 2002 | 03:08 AM
my96z's Avatar
Post
Looked like you hooked damn good. Congrats.
Old Sep 14, 2002 | 07:15 AM
RichJ's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by TravProcharged94Z:
Later
Travis
</font>
Thanks, Travis. The 60 on that run was a 1.69. Two passes later I ran a 12.29 with a 1.71. You would definitely get deep into the 11s if you could get a better short time. I'd highly recommend ET Streets for that.
The exhaust is a custom set-up fabricated at Mufflex's shop on the car. Hooker LTs into a 2-1/2" stainless y-pipe into a 3"x17" Dynomax bullet into a 3" Borla XR-1 oval muffler. It's actually very mellow and quiet on the street.
Thanks,
Rich
Old Sep 14, 2002 | 09:06 AM
Jerm93z28's Avatar
Post
did i just hear you chirp 4th with et streets?
jeremy
'93 z28 m6 (Purple Pearl Metallic)
stock shortblock, 230/236 cam, mildly ported heads, hooker longtubes, csi waterpump, all the usual bolton stuff.....
7.98 @ 88.7mph 1.84 60' (1/8mi)
Old Sep 14, 2002 | 01:26 PM
hotrod18_69's Avatar
Post
Very nice,
Remember #3
97 Z-28 Silver A4
MODS and pics on my web page..
Track times.
13.50@102.89
Check out my web page.
hotrod.cz28.com
clarioncorvette.com
Old Sep 14, 2002 | 10:55 PM
funina91ss's Avatar
Post
what did you do rent the track looks like you were the only one there lol... Nice job
Old Sep 15, 2002 | 12:10 AM
RichJ's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by funina91ss:
what did you do rent the track looks like you were the only one there lol... Nice job</font>
Close...there were 16 of us that rented the track for the day.
Rich
Old Sep 16, 2002 | 08:13 PM
T/A lt1's Avatar
Those are nice times and a cool video. What cam were you running before the xe comp 230 u are running now? Did you notice a big improvement? I am running the Hotcam and contemplating going with that cam. My car runs 12.5's with 3.42 's in the heat so I am expecting 12.20's with 3.73's and cooler air but I have an auto. Just trying to figure out if a cam swap is worth it or not. Later
Old Sep 16, 2002 | 08:40 PM
Jerm93z28's Avatar
i havent run the 1/4 yet, but from the looks of your times, me thinks i could run a high 11 with your 60'.
jeremy
Old Sep 16, 2002 | 10:42 PM
RichJ's Avatar
Thanks for the compliments
I don't think a HOT cam is much different from what I have. Both are good for about 360-370 rwhp. I've got a friend who runs about the same times with a HOT cam (12.2@112) and an M6. If you want a meaningful power increase and want a comp cams xtreme, I'd go to at least a 224/236.
Rich
Old Sep 16, 2002 | 11:24 PM
sideways_Into_3rd's Avatar
at what rpm did u launch ?
did u pop 'er or slip it a bit ??
are u using a stock driveshaft or a stock torque arm ?
i get similar mph with my car and im wondering how far i can push my luck with my street twin, 12 bolt and et streets and stock torque arm
Old Sep 17, 2002 | 12:38 AM
Jerm93z28's Avatar
Let 'er rip!!
sideways- i wouldnt worry about the stock torque arm till you get down to a 1.6x 60'. if your running an aluminum driveshaft, thats more of a worry than the torque arm. the stock steel one is stronger than a LS1 shaft.
heat those et's up, and dump the clutch from 4500 or so and you should be grinning ear to ear.
jeremy
Old Sep 17, 2002 | 08:05 AM
RichJ's Avatar
~5500 rpm launch with no slip.
Denny's driveshaft and a BMR torque arm (my mod list is in the link below)
I broke two stock torque arms last year with 4000 rpm launches and then went to the BMR. I don't think my experience is typical, though it seems to be more common with Moser 12 bolts for some reason.
RichJ
Old Sep 26, 2002 | 09:43 AM
rncotton's Avatar
Nice run ...
<DROOL>
HAWG
Sep 25, 2015 11:41 AM
cmsmith
Sep 14, 2015 09:09 PM
mark0006
Sep 14, 2015 12:35 PM
Daluchman1974
Sep 11, 2015 06:12 AM
