new best
Old May 25, 2006 | 07:28 AM
ss97dml's Avatar
new best
11.09@ 121mph 1.56 60'
Old May 25, 2006 | 09:45 AM
rje's Avatar
rje
Re: new best
What was your 1/8 time and mph? If your street driven that's pretty good, but you still have alot left on the table.
Randy
Old May 25, 2006 | 04:27 PM
ss97dml's Avatar
Re: new best
1/8 7.086 99mph
Old May 26, 2006 | 11:03 AM
rje's Avatar
rje
Re: new best
That's pretty good, but your mph suggests that you can run in the 6.7's if you could dead hook the car. I imagine that you are spinning the tires even with a 1.56 60ft being that your running a boosted stroker, and if you did hook up hard you may find that you start breaking driveline parts. Good Luck!!
Randy
Old May 26, 2006 | 12:02 PM
CANTONRACER's Avatar
Re: new best
Congrats...curious why your 1/4 MPH seems slow for the 1/8 you get. Does it trans slip? Running out of fuel?
I would be expecting 125 mph at least.
Old May 27, 2006 | 05:05 PM
big dave's Avatar
Re: new best
I too think that your mph should be a bit higher...especially considering what you're getting at the 1/8th. What size tire are you running with those 3.73s? You must be pretty close to redline going through the traps. I'm usually around 5900 at 113 mph.
The car is still pretty quick though and I believe you do have the makings of a solid 10 second car. Good luck.
Old May 27, 2006 | 09:21 PM
ABA383's Avatar
Re: new best
What Big Dave and Canton said...I'm hoping for your times/mph N/A...Something's going on between the 1/8 and the end...You've got a good 1/8...Whats your set up like? Sorry, not at all trying to crap on your new best...Congrats!!
--Alan
Old May 28, 2006 | 08:41 AM
ss97dml's Avatar
Re: new best
m/t 26x8.5x15 et drags,adjustable rear suspension- torqe arm,panhard rod,lca's,air bag,built tranny,fuddle 3400 stall. rest in sig and only running 8lbs. of boost.
Old May 28, 2006 | 08:45 AM
ss97dml's Avatar
Re: new best
no spinning,tuned perfect and it shifts at 6700-6800 like clockwork i also had my tank sumped and a bosch pump good for 800hp.
Old May 30, 2006 | 10:16 AM
blksunshine's Avatar
Re: new best
nice times, whats the weight, maybe thats why the mph is lower in the 1/4
Old May 30, 2006 | 04:43 PM
ss97dml's Avatar
Re: new best
stock weight,even the spare.thinking of taking off the front sway bar and the spare out.
Old May 30, 2006 | 05:01 PM
big dave's Avatar
Re: new best
I'm glad you started this post, I have a p600b that has been sitting in a box for the past 6 years. I've been contemplating reinstalling it but had no idea what it would run with my heads/cam package. I may not be as fast as your car but should be in the vecinity.
