need some launch suggestions?
Old Mar 28, 2006 | 10:11 PM
blackztpi's Avatar
i'm going to pilot a 6 spd head/cam car with 3.73's in a stock 10 bolt. the runs will be made for trap speeds mostly, but i don't want to go out there and run 14.5@114. any launch suggestions for stock tires and a 10 bolt with the 6 speed? i've never driven anything i have to pamper off the line like i will this one. any tips for getting going while keeping 60's in the 2.0 range?
Old Mar 28, 2006 | 11:11 PM
Bow94z's Avatar
Re: need some launch suggestions?
Um drag radials...then prolly slip the clutch from 2k
Old Mar 29, 2006 | 06:27 AM
TQdrivenws6's Avatar
If you are on a true street tire, just do what you can to stop spinning. If you are on MT DR's then I would say a 3000-4000rpm quick slip but preload the drivetrain at the second yellow.
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
tommalcolm
Sep 11, 2015 03:39 PM
Daluchman1974
Sep 11, 2015 06:12 AM
