need 60' in the 1.6x range
How can I get my 60' in the 1.6x range? Right now im running 3.23 gears, detriot tru-trac locker, lcas, and nitto 555s. I cutting constant 1.75 60' now. Need to bring that on down by another tenth.
suggestions?
suggestions?
Only suspension is the lcas, im afraid of gears (shreading teeth), power is low...about 315 rwhp 325 rwtq. Any suggestions besides is the ta worth it? Im thinking front shocks and springs. what do you think?
Thanks,
Pride
Thanks,
Pride
it does not feel like im spinning. Im leaving the line pretty hard, I mean I am cutting 1.75 60'.
My primary goal is to 12.0 all-motor; I thought I could do this by dropping the 60'. But I really dont want to raise the gear, bc i am afraid that when I spray it, that I will shread the teeth on the gear.
I was thinking maybe the front suspension but I dont really know how much that will help.
If you are not spinning nothing that you do to the suspension will help. Suspension work is to get the car to weight transfer and hook to improve traction.
Now if it's spinning then it's time for some suspension work.
NewsBot
Sep 14, 2015 02:02 AM
Aug 7, 2015 08:52 AM
