my drag setup
Old Aug 5, 2008 | 02:05 AM
kempfs92's Avatar
my drag setup
my car is a 92 RS sleeper,lol
heres my setup
L98-5.7 tpi
Dart 215cc iron eagle heads.2.05 v 1.55 roller springs.
Tpis 22-x camshaft
.598 lift ,242 @50 duration,hydrualic roller cam
Crane cam gold 1.6 roller rockers
Tpis mini ram intake
42 lb injectors
1000cfm 58mm holley t.b
180thermostat
Underdrive pulley,smog pump pulleydelete.
Stock ecm tuned,ed wright superchips,
Hooker super comp longtube.
1 3/4 headers, 3in collector in 2.5
96 ss t56 6sp trans,spec stage 3 clutch
Pro 5.0 shifter,aluminum 1le driveshaft.
Moser 12 bolt,33 spline gun drilled axls.
Us gear 4.30 gears with spool
Susp.
T56 cross member w/ driveshaft spool
T56 adj. Torque arm set @ -1
Rear anti roll bar
my personal best is a 11.90 @ 115 with a 1.60 60' With stickys
Old Aug 7, 2008 | 11:14 PM
sn8ke eatr's Avatar
pics of car?
Old Aug 7, 2008 | 11:45 PM
AutoRoc's Avatar
Where are you from? Pics would be very cool. Sounds like it runs pretty good. Any idea what rpm it is at when you cross the finish line in 4th at 115mph? Just curious because you have a 4.30 gear. My guess is 6200 if you're on a 26" tire.
My first EVER time racing my old red IROC at the track...I was beaten BADLY by a purple 92rs that didn't look like much. It was faded and had some cruddy black rims with beat up slicks on them...he ran 12.90 to my 14.88.... I was shocked by that car...I'm sure you're would make my jaw drop more if it truly is an 11.90 sleeper rs... Welcome to cz28.
Old Aug 9, 2008 | 12:21 AM
kempfs92's Avatar
needs a bath,
Old Aug 14, 2008 | 10:18 PM
IrocSS85's Avatar
awesome, loving it. hows that cam ridin around on the street? bet the 4.30 gear makes it drive pretty nice still.
Old Aug 15, 2008 | 12:35 AM
kempfs92's Avatar
Yea,I think its plenty , the gears do make it nice to drive still.
RUENUF
Mar 13, 2016 03:37 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
