The LT1 runs 11.24@120.8mph!
Old Nov 27, 2004 | 09:36 PM
  #16
T/A lt1's Avatar
Re: The LT1 runs 11.24@120.8mph!
Thanks guys I was going to go either blower or turbo b/c I was having bad luck with engines so I sold my heads/cam, intake and injectors to build a low compression engine when I came across this killer set of heads and the old CC306 and decided to give it a shot. Also my wife was complaining about me buying a blower/turbo, tuning, new heads,intake,cam etc.. so I jumped on the deal and the car has never run so good on motor. Having a good PCM tune and 60' times are what makes these cars really start to fly I can tell you guys that much. Later
Old Nov 28, 2004 | 02:31 PM
  #17
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
congrats!! lookf forward to seeing how she hauls on the bottle.
Old Nov 28, 2004 | 05:54 PM
  #18
T/A lt1's Avatar
Won't be as fast as yours Taner but I expect 9's with a 200shot I can tell you that much!
Old Nov 29, 2004 | 05:30 AM
  #19
Mac 93 Z's Avatar
Originally Posted by T/A lt1
Thanks, the setup is so simple and not too expensive either. Just finally getting the car sorted out and running the way it's supposed too with heads and a decent cam. Later Clint
I'm in the process of doing the same thing with my LT1 ...sorting stuff out to make it all come together. Congrats on the new best !! My next time out ,I plan on running a set of 26's too. The 28's are killing my 4.10 gear on the bottom end. I see where you plan on a pair of 28's in the future . May I suggest a pair of 27' Hoosiers ?? I think this will be the perfect middle of the road tire for both of us. Congrats again,man !!
Old Nov 30, 2004 | 01:45 PM
  #20
T/A lt1's Avatar
Thanks mac but you running 28's/4.10's is still a lower ratio than my 26"/3.42 combo so I think the 3.73/28 or 27's which I also plan on trying b/c I probably won't have to cut anything to go with the Hoosiers which would be the best route and still have some more 1st gear. The 28's would be for n2o though. Later and Goodluck.
Old Dec 1, 2004 | 09:15 AM
  #21
big dave's Avatar
Damn good times. Congrats. It would be nice to see a small cube lt1 in the 10s. I wish I didn't have to worry about emmissions, this small cam is killing me.
Old Dec 3, 2004 | 09:19 AM
  #22
blksunshine's Avatar
Clint, Good times. I am glad the shocks worked out for you, which springs did you use?
Old Dec 3, 2004 | 05:50 PM
  #23
flyinZ's Avatar
Nice man..heh, nice. You wouldn't happen to have any footage of that would ya?
Old Dec 4, 2004 | 07:55 PM
  #24
T/A lt1's Avatar
BlKsunshine I just bought the Hal springs for $100 and everyhting works well Thanks. I have some video from a friend that he is going to e-mail me but he said it's not great b/c of nighttime racing. Later Clint
Old Dec 5, 2004 | 10:14 AM
  #25
Fast Caddie's Avatar
Clint:
I was wondering... are you were running a T-brake? A buddy of mine with a GN is running a TH350 with a 3500 stall. I forget the difference in 60' times, but after installing the brake he knocked off about 2-3 tenths from his 1/4 times.... might be your ticket to 10s with that setup. Of course, that might mean buying a 12-bolt a little ealier than expected though.
Old Dec 6, 2004 | 03:31 PM
  #26
T/A lt1's Avatar
No, I don't have a transbreak but plan on installing one in the near future(after the rear is in). I know the car is making enough power to go high 10's but it needs some more 60'. Later Clint
Old Dec 6, 2004 | 04:07 PM
  #27
taner's Avatar
Awesome!
Old Dec 9, 2004 | 05:08 PM
  #28
LT4POWR's Avatar
11.24@120.8mph! This with a 3800 converter, 3.42's in the stock 10 bolt and a 3450lb raceweight. The engine is 355" with an old CC306 and a tune from the internet.
That's awesome How much compression are you running? You've gotta be making around 410-420 rwhp.
It's funny how the "old tech/lobe" cams like the CC306 and GM847 seem to always out perform the new CCEX lobe cams.
Old Dec 9, 2004 | 06:18 PM
  #29
I've often wondered that myself. I know the XEs make more area under the hp/tq curve and make a very defined, solid powerband. Maybe it's because the standard ramps can get more rpm? Stronger top end?
Old Dec 10, 2004 | 03:35 PM
  #30
T/A lt1's Avatar
You guys are right those new cams don't seem to make much if any more power. My engine is about 10.5.1 b/c I am running the thicker Felpro .039 gaskets instead of the Impy gaskets. Later clint
