Line Lock pics
Old Nov 20, 2006 | 04:18 PM
Mike Comp T/A #57's Avatar
Line Lock pics
Now that I have slicks, it was hard to do a burnout without an Line Lock.
I installed a SLP solenoid with a Hurst button.
P
Old Nov 20, 2006 | 04:58 PM
ABA383's Avatar
The SLP system is very nice (I have it, too)...I put the switch in the ashtray...Saving the spot you used for the TC lock up switch...
--Alan
Old Nov 21, 2006 | 12:49 PM
romoranger's Avatar
hey, what else did you need to install that? just the switch, or do you need the install kit as well?
Old Nov 21, 2006 | 03:00 PM
ABA383's Avatar
I bought the whole kit from SLP which includes pre bent lines, solenoid, wire, and switch...Its all inclusive and works/looks great...Just bolt in, wire up, bleed brakes and go..
--Alan
Old Nov 21, 2006 | 07:15 PM
The Engineer's Avatar
I have the SLP line-lock and it is a neat kit, however, I didn't like the toggle switch. So I installed a push-button on the steering wheel.
WD
Old Nov 22, 2006 | 02:20 PM
Pampered-Z's Avatar
How did you connect the buttom to the shifter? I have a manual so it was easy to just unscrew the handle and slide the switch over the shifter. What did you have to do to install on an auto's shifter?
Old Nov 22, 2006 | 04:57 PM
I knew someone would ask that. I used "thick" super glue.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95chwagon
Jan 13, 2015 09:19 PM
