Launching an A4 w/street tires
Old Jul 11, 2006 | 01:59 PM
user 647483's Avatar
Have not been to the track in years.
Even longer since I've done so on street tires.
The Hawk will see it for the first time in the next week or two.
As soon as the heads/cam are on and tuned
I'm running 3200 Stall and 3.73s on an A4 with street tires.
She'll put ~375 or so to the rear wheels.
Lowered on sportline springs (was that way when I got it) and adjustable shocks.
Running tubular panhard rod, boxed LCAs and stock torque arm.
Any tips on launching this car?
Adjustment suggestions for the shocks? (currently set to "like a sheet of plywood")
It'll be at KCIR (Kansas City), which is something like 800ft above sea level if that matters any.
Typically 80-90*, high humidity.
Old Jul 11, 2006 | 05:11 PM
Jameslt1TA's Avatar
Re: Launching an A4 w/street tires
I never did get good at launching street tires....i would just try to find some salad shooters or something real quick and put some drs or et streets on them. 375 horse and 3.73s with a 3200 stall will be difficult to launch.
Old Jul 11, 2006 | 05:20 PM
Originally Posted by Jameslt1TA
I would just try to find some salad shooters or something real quick and put some drs or et streets on them.
Yeah, a set of drag rims and rubber are next on the old mod list.
In the mean time, I'll be running on fresh Z-rated street rubber.
Old Jul 12, 2006 | 03:00 PM
Jameslt1TA's Avatar
Hey then you will have a good comparison to see how much you gain with better tires. Wish i could help you more for your launch technique...but i would just find a back highway or something and practice until you've got it down good without spinning. Sure the track will grip better, but you wont go out an spin through all 3 on your first try if you practice beforehand.
Old Jul 12, 2006 | 03:15 PM
That's pretty much what I've been doing LOL
I'll get the car back with the heads/cam this weekend.
I may just have to learn to ease in on the pedal until I get DRs.
One of the local shops rents KCIR out for test/tune quite a bit.
I could probably get quite a few runs in just to practice launching.
Should I warm up street tires? (burnout) or not?
I'm not sure if it helps with that kind of rubber.
Old Jul 13, 2006 | 07:41 AM
Jameslt1TA's Avatar
No dont heat em up. All that does is make them slippry. Just give em a quick turn to clean of any junk that might be on them...oh and drive around the waterbox.
Old Jul 13, 2006 | 08:26 AM
I've never actually noticed a waterbox to drive around at KCIR.
It's probably at the other track entrance.
Quickss96
Jan 29, 2016 05:56 PM
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
Latronaxe
Jul 20, 2015 12:00 PM
Boss002
Jul 9, 2015 03:33 PM
Slayer
Jul 4, 2015 03:06 PM
