launching a4 with line locks
Old Nov 24, 2006 | 01:05 PM
myslowcamaro's Avatar
i was thinking about getting line locks but wondering if the front brakes alone would hold an a4 back with a 3600 stall without breaking the beam. anyone use them in an a4 in this manner? also, anyone know if you set up the pressure swith on the steering wheel or easy access?
Old Nov 24, 2006 | 06:14 PM
AL SS590 M6's Avatar
Moderator
Won't work. To even try to stall up you need 4 wheel brakes.
Old Nov 25, 2006 | 06:25 AM
Projectz28's Avatar
Moderator
a line lock is for making the burnout easier. It wont help on launch. You need all 4 wheels locked to hold the car in place on the starting line.
Old Nov 25, 2006 | 06:52 AM
The Engineer's Avatar
Also, most NHRA bracket classes and local track rules for No-E do not allow the line-lock (front wheels only) to be used for anything other than the burn-out. Basically the rules require the car to be foot-braked at the line for the launch.
I used a TCI transbrake button on the steering wheel for the line-lock which I find convient.
WD
http://www.cardomain.com/ride/2189634
Old Nov 25, 2006 | 08:40 AM
WD
thats what i was afraid of. i cant get a trans brake for a 4l60e or 4l65e im told. thanx guys
Old Nov 25, 2006 | 10:40 AM
If you're not planning to run an NHRA bracket class (Summit Racing Series, i.e.) it really isn't an issue. However, most bracket rules for No-E restrict the use of line-locks and trans-brakes for the No-E class.
Also, auto or air-shifters are not allowed unless they are factory. Therefore, your 4L60E has a "big advantage" with the very precise programmed shift points and consistency over manually shifted cars in No-E. And, that is one of “many reasons” I enjoy running my Z28 (LT4 396 w/ A4) in bracket racing.
WD
Old Nov 25, 2006 | 07:52 PM
Moderator
Yes you can
Old Nov 26, 2006 | 08:48 AM
Originally Posted by AL SS590 M6
Yes you can
any links or phone numbers al? everyone i called says they dont exist. would be much appreciated.
Old Nov 26, 2006 | 06:52 PM
Moderator
Rossler has one out now
Old Nov 27, 2006 | 11:29 AM
cwaldt's Avatar
KYLE@CSS can help you. Hes a sponsor here and builds trans. He can also put your trans brake in for you.
Old Nov 27, 2006 | 08:15 PM
maybe ill buy a trans brake from him but i promised frank at cpt the rebuild work
Old Nov 28, 2006 | 11:25 PM
Jlo's Avatar
Jlo
WD
What steering wheel is that, I plan on using somthing the same set up as you, except on a 6speed with a line lock and a 2step.
Old Dec 2, 2006 | 07:45 PM
Jameslt1TA's Avatar
Frank from cpt told me that you can get a trans-brake for the 4l60e/700r4, but they aren't the greatest and you would be better off just footbraking it.
Old Dec 2, 2006 | 11:31 PM
Moderator
There's a guy on LS1tech.com that hs run one from Rossler with nitrous all summer and had no problems and loves it.
Fastbird93
Apr 9, 2016 07:01 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Pampered-Z
Apr 14, 2015 05:38 PM
rje
Sep 9, 2002 12:35 PM
