LAUNCHING!!!!??????
Old Aug 7, 2002 | 01:47 PM
bigcat-93zm6's Avatar
Post LAUNCHING!!!!??????
I know you guys have probably answered this a thousand times, but it will my first time at the track soon and just looking for the best methods to launch my car and or tips. thanks. oh on street tires
93 z28 m6 k&n c.a.i. chip, flowmaster cat back 3:23's
Old Aug 9, 2002 | 02:54 AM
twistedwedge's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by bigcat-93zm6:
</font>
Realy it all depends on what trans you have in that car. In '93 GM made 2 T-56 trans with different gear ratios.
The launch will have to be done very carefully...with those 3.23 it should be interesting...If you ride the clutch to keep from bogging you most likely will fry the clutch, and if you dump it too quickly it will spin a whole bunch or just bog. I would try it out a bunch on the street and see what method works best. I always had luck with easing the clutch out equally with throttle pressure, and not too quickly on the clutch release.
1987 GTA- TH400 w/brake, 355, carbed, 11.3:1, TFS twisted wedge heads (non ported), Big Shot NOS, Lunati hyd roller .510/.525 lift 232/242 duration @.050, true dual 3" exhaust, hooker super comp 1 & 3/4" headers, flowmaster 2 chamber mufflers, no tailpipes, 6-pt roll bar strange 12-bolt w/ spool and 33 spline axles, BMR anti-roll bar, BMR LCA relocation brackets, BMR solid rod end panhard bar, PA tubular k-member and a-arms, PA coil over conversion, PA manual rack conversion, Weld Pro-Stars 15X10 w/28X12.5 ET Street out back, 15X3.5 out front
Best ET last year N/A,Stock suspension, on street tires, T56, stock rear end and 4.56's @ 3515 lbs: 12.46@115.1 (1/4) 8.15@90.5 (1/8)
drive it like you stole it!!
Old Aug 9, 2002 | 07:55 AM
Ken95Z28's Avatar
Post
Practice Practice Practice
Also avoid of going through the water box.
1995 Z28 A4 3.42 Best ET(12.205@109.50) LT4 Hot Cam, 1.6RR's, K&N FIPK, 85mm MAF, Mac Header & Y-pipe, Flowmaster Exhaust, CutOut, Yank ST3500, TransGo Shift Kit, LT1 ScanMaster, CSI WP, M/T ET Streets, 6-point Wolfecraft and Ed Wright Programming
Ken's 1995 Z28
F-Body Fastest List
"Never be afraid to try something new. Remember that amateurs built the ark. Professionals built the Titanic."
[This message has been edited by Ken95Z28 (edited August 09, 2002).]
Old Aug 10, 2002 | 12:27 PM
Fastbird93's Avatar
Post
This is what I do: I run it up t o 4k rpm, and when I go I feather the clutch out while planting the gas. I'm only on the clutch for a split second, and I'm still perfecting the technique, but look at my 60' times. On a nearly stock car, try to only run it up to about 3k, and com off the clutch faster. Just keep trying until you find something that works.
Active Duty USAF 93 T/A M6 (M29) - Hypertech Powercoil, B&M Shifter, 97+ Console, Chrome WS6 ims & SZ50's, AZ S&M Headers, Random Tech 3" Cat and stainless Cat Back, TB bypass, OEM 97 Ram Air, Custom Chip, 160 t-stat
Best time: 13.193 Best mph: 104.76 Best 60': 1.923
Daluchman1974
Sep 11, 2015 06:12 AM
Critter
Jul 13, 2015 05:51 PM
Injuneer
May 15, 2015 08:45 AM
mark0006
Dec 25, 2014 09:50 PM
