Launch RPM's
Old May 1, 2009 | 09:43 PM
96SSIndeed's Avatar
Launch RPM's
OK, so my mods are in my sig. i have a stage 2 spec clutch and an m6, with my new 9" rear and 4.11 gears and Nitto 555r's . What would be a good starting point to launch this car at? Around 3000-3500rpms was doing pretty good, sometimes it would spin and sometimes it will bog, which i attribute to needing a tune and will have by the next time i go to the track. I was thinking about trying 2800-3500 rpms. I know the car will dead hook with my suspension setup and these tires with a good burnout, thats what broke my 10 bolt. Any input from more experienced racers would be appreciated.
Thanks Chris
Old May 3, 2009 | 08:08 PM
reamo04's Avatar
sounds like you know where it will hook and where it will spin so why are ya askin us? Just vary it by couple hundred RPM and try different things
Old May 4, 2009 | 06:03 PM
96SSIndeed's Avatar
lol. yea, i know where she'll hook. i was just wondering because i know sometimes a car will be faster with a little wheelspin. basically i wanted to know whether it was worth the launching that high if a lower launch would work just as good.
Old May 5, 2009 | 06:44 PM
AutoRoc's Avatar
If you went to a true slick tire, and launched at 5000rpm..A little spin would work well and you'd be accelerating very fast...haha The Nitto's aren't that forgiving and the quickest way wih them is like any street tire...Severe clutch slip while in the meat of the powerband, while not spinning the tires.. Not a job I'd want...It's tough from what I always see.
you have very good parts, just not the right tire.
To keep rpm's in check, I'd use a 2 step setup and vary launch rpm that way. It's one less thing to think about if you're trying to be consistant. Be it for bracket race reasons or just trial and error/test n tune results.
Old May 5, 2009 | 08:00 PM
96SSIndeed's Avatar
I agree i will be looking into a 2-step soon enough, i have had great success out of them with my old full race civic. I always heard a slick was over kill up to about 450rwhp, or do you mean ET streets?
Old May 6, 2009 | 06:57 AM
AL SS590 M6's Avatar
Moderator
Full slicks on anything other than an all out fulltime very quick race car are a thought from the past. The drag radials out there now will hook anything slower than 9s with the reliability of a slick.
I've tried Hoosier and Mickey Thompson and they both easily dead hook my high 1.4 sixties.
Old May 6, 2009 | 07:44 PM
96SSIndeed's Avatar
Very nice to know, i guess when these nittos wear out i can get my craggars with the et's streets.
Old May 7, 2009 | 12:54 AM
6SpdLT1Z's Avatar
Don't forget you can play with the tire pressures too. Start high and let a little out.
Old May 8, 2009 | 12:18 PM
96SSIndeed's Avatar
Right. last itme i started at 28 and ended up at 22, which dead hooked at 4500rpms
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
Daluchman1974
Sep 11, 2015 06:12 AM
