How much pressure in Nitto 555
Old Apr 26, 2004 | 05:56 PM
97zko's Avatar
I just need to know how much pressure i should put in my Nitto 555?
Old Apr 26, 2004 | 08:18 PM
CanIroc's Avatar
For the track? Start at about 20 psi and go lower or higher as needed.
Bob
Old May 3, 2004 | 06:11 PM
DanBUCF's Avatar
I've had best results running 16 lbs....its what I run everytime.
Old May 7, 2004 | 09:52 AM
Bad AZz Z28's Avatar
what size nitto? and do you mean street pressure or I assume you mean track pressure?
my 17in nittos I ran at 20psi on the street and 17 at the track
with my 16in nittos I ran at 22psi on the street but didnt use them at the track, probably would have went with the same 17-18.
just go to the track and play around with what works
Old May 7, 2004 | 12:14 PM
TedH's Avatar
I would start at 20 pounds and adjust either up or down as necessary. It will be a trial and error event as each car is unique.
Old May 8, 2004 | 07:30 AM
'94 Bad A Z28's Avatar
I run my Nitto NT555R's at 15psi hot for the track. I cut a best of a 1.76 60' with stock suspension and a lowered car.
KYWes
Jun 14, 2022 06:52 AM
HibachiZ28
Nov 6, 2015 12:53 AM
350350
14
Aug 11, 2015 12:03 PM
mrwz28
Jul 8, 2015 09:11 PM
