Hooking up the T/A! Launch pics inside.
Old Feb 5, 2010 | 06:56 PM
  #16
fastfox's Avatar
car looks good dude saw you at the track .nice
Old Feb 5, 2010 | 08:10 PM
  #17
T/A lt1's Avatar
Thanks I really appreciate the compliments. Where do you live and what do you drive/race? Whats your name? I plan on going back in 2 weeks with some dyno tuning, swapping to 3.73's gears and the limiters set on the tight side. I should have video this time. later Clint
Old Feb 6, 2010 | 07:43 PM
  #18
1BADAIR's Avatar
what TA?
you can play with anti squat and instant center using the TA also.
measure the LCA angle
Old Feb 7, 2010 | 11:17 AM
  #19
fastfox's Avatar
i live in baton rouge la i was with my lil brother in his 69 camaro but i have a 1997 ss almost done.my name is duston,
Old Feb 27, 2010 | 10:10 AM
  #20
ABA383's Avatar
Looks nice Clint! I don't get over to this site to often..Looks like you'd definitely benefit from some good adjustable rear shocks. Even if you cheap out with some QA1 12 ways and experiment with stiffening them up until you get a bit of shake and then backing them out a click...FWIW I run QA1 12 ways set on 8 and it really helps to drill the tires into the track without the squat...and I still use the stock rear springs...
--Alan
Old Mar 3, 2010 | 05:10 PM
  #21
deerslayinrenek's Avatar
Originally Posted by Injuneer
Do you have LCA relocation brackets? They will generally push the back end up, forcing the tires against the asphalt. Add limiters in the front, and you can get it to launch like this:
http://www.injuneer.com/images/photo...B/IMG_0710.jpg
First launch, after the car was set up by Steve Spohn in his shop.
I love the way that car leaves, in fact that pic has been saved on my pc for a yr
Fastbird93
Apr 9, 2016 07:01 PM
shroyvin56
Apr 19, 2015 09:40 PM
PROJECT X
Apr 17, 2015 12:13 AM
Ed95Pont
Jul 23, 2002 08:26 AM
