Here's PROOF on how gearing will affect your cars times
Old Apr 17, 2004 | 01:14 PM
Fastbird93's Avatar
The car is a 93 Trans Am, ported heads, hotcam, full exhaust, ect. It has a 95 T-56 and the stock 3.23 rear gear ratio.
This car, under the previous owner, went 12.69@105 with a 1.74 short time. It had the stock auto and a 3200 Vig covertor, and the 2-3 clutch packs were burned up, as he was bouncing off the limiter.
The previous owner swapped in the 95 T-56 (do some searching around, there's different gear ratios in the M6 between 93 and 94+), but never got it to the track.
I went to Atco on Thursday night.
First run ever with this car, was:
2.12 short time, 13.16@106.9 bouncing off the 6200 limiter while in THIRD gear.
Next run was the best:
2.04 short time, 12.988@107.98. I upped the limiter to 6400 and was crossing the traps in third at 6200 rpm.
Can you say undergeared??? 3.73's are going to wake this car up big time.
Old Apr 19, 2004 | 01:11 AM
Mikey 97Z M6's Avatar
Thumbs up
Ya, gears will help big time if you can hook it up. When my car was stock I picked up 3mph and 4/10ths et after I installed the 4.10's.
Good luck with that car man.
Mike
Old Apr 19, 2004 | 01:17 AM
Red5.7's Avatar
Mike
Yup, I picked up 3 MPH switching to 4.10s as well, but my traction and technique isn't there yet, so I am still running about the same ET. I usually trapped in the 99 MPH range with 3.42s, now I am in the mid-high 102s. Just need more seat time to get the car dialed in!
Old Apr 19, 2004 | 03:12 PM
andy katzelis's Avatar
I can't remember the MPH but:
2.73 gear -14.20
3.73 gear - 13.70.
All stock.
Old Apr 22, 2004 | 01:53 PM
dobe's Avatar
stock 10bolt 3.42 i went 112 - 113mph got a 9" now with 4.10's no other changes same 17" nittos and ran 117mph on a not so great day.. trapping 91.5 mph that day in the 1/8 and i was trapping 94 and 95mph in 1/8
santore
Old Apr 28, 2004 | 09:10 PM
soontobeGN's Avatar
do you guys think with my current setup, I have a lot to gain going from 3.23 to a set of 3.73? My best times so far have been 13.6 @ 102. Only mod is the full exhaust(LTs and true duals, no crossover pipe).
Old Apr 29, 2004 | 01:16 PM
Lt1 and Ls1's Avatar
4:10's here I come!!
Old May 2, 2004 | 01:35 PM
whoa guy's Avatar
i upped to a better posi and 3.73 in my old 'maro. Big diff IMO from the stock 3.23's. a few tenths diffrence....
Noenav
Mar 1, 2019 07:38 AM
ChrisFrez
Dec 15, 2014 03:09 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
