Guys with approx. 350hp and 4.10s
I was just curious because I'm getting 4.10's put on and I want to know where you guys normally launch in the powerband and what kind of 60ft. times you can pull off WITHOUT slicks. All input appreciated...
Well my best 60' with the 4.10's has been 1.60. I usually cut low 1.7's with the stock clutch.But after 50+ passes its definately showing signs of wear and I am not launching as good.I dynoed 342/352 to the wheels and I launch between 3800 and 4300 rpms depending on the track.Hope this helps.
