First time at the track in the Z.
Old Sep 15, 2010 | 07:53 PM
30th_ANNIV_Z28's Avatar
just curious, is a 14.4 @ 95 horrible for a 97 Z with no mods? i have never been to the track before so im not sure what a stock z normaly runs at.
Old Sep 16, 2010 | 06:32 AM
AL SS590 M6's Avatar
Moderator
Depends upon the weather and altitude of the track on the day that you went.
If it was really hot and humid with a low barometer it'll be slow. Higher altitudes make cars slower too.
What was the weather when you went? What track/altitude?
Old Sep 16, 2010 | 11:03 AM
Z28SORR's Avatar
Speed and time are a little slow. That's closer to Vert, territory. Mine did a best of 14.7 stock, 3800lbs. Should be high 13's.
Old Sep 16, 2010 | 01:05 PM
OutsiderIROC-Z's Avatar
What was your engine temp? I found my LT1 ran better when the temp gauge was just right off the peg on the low side. Above that it slowed down drastically.
One time I hotlapped it out of curiosity to see how much. The first pass was a 13.93 with the temp gauge right off of the peg. The next run probably a few minutes later with the gauge probably between a quarter and half way up it ran a 14.34.
Old Sep 16, 2010 | 10:21 PM
mad95z's Avatar
Stock LT1 cars that i have seen run are usually in the mid 14's.
If you have 2.73 gears that wont help at all.
I am from MN also, What track did you run at?
Old Sep 17, 2010 | 09:44 AM
Z28SORR's Avatar
It's a 30th annivercary Z28, so he should have the 3.42 gear, I think?
Old Sep 17, 2010 | 10:17 AM
razor02097's Avatar
First you need to correct your ET and MPH.
http://www.bgsoflex.com/etmphcorr.html
Second the time that was posted is pretty much on par with a stock LT1. Yes you can go faster with practice and tweaking this and that but you need a baseline which you now have.
Old Sep 19, 2010 | 09:11 PM
canuck94z28's Avatar
That sounds about right.My 94 ran 14.4@1600ft. on a street legal fri. night test/tune (no traction compound) back in 1998.
Old Sep 23, 2010 | 10:24 AM
im stationed down in north carolina i went to kinston drag strip. elivation is arround 40-50 ft. im pretty sure there 2.73 gears
Old Sep 23, 2010 | 07:05 PM
slowride94z's Avatar
http://www.dragtimes.com/da-density-...ect+ET+and+MPH
I like this one better. you run what you run when you run.
no if, could, or whatever
use this for comparison or bench racing
to the op, no that is not bad I know "fast cars" that couldnt do that good
Old Sep 26, 2010 | 01:33 PM
white97T/A's Avatar
What was the 60' time. Keeping that down makes a huge difference in the total E/T. 14.4 does not sound too bad for a first time out. I ran a lot of
14's when starting out, and with patience and practice finally ran a best of 13.6 while still stock. (probably in ideal weather too!)
Old Sep 28, 2010 | 09:33 AM
Z28SORR's Avatar
Check your RPO Codes (on the glovebox lid), GU2=2.73 GU6=3.42
Old Sep 28, 2010 | 02:00 PM
El Spider's Avatar
Thanks for the tips everyone!
Feffman
Oct 9, 2015 05:42 AM
Louey
Pacific
Jan 25, 2015 12:22 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
Louey
Pacific
Dec 8, 2014 08:01 PM
Louey
Pacific
Dec 1, 2014 04:16 PM
