first time on track
first time on track
ran last night for the first time ever.
anyone see a way of improving this time. car has 1.6 rockers, cai, shortys, m6 lt1. tires are pirelli pzero 285/35/18
2.48 60ft
6.38 330ft
9.48 1/8
79.6 "" mph
12.1 1000ft
14.34 1/4
101.15 mph
this was my first and best run suprisingly as i bogged off the line.
had a couple runs after that launching at 2300 but spun hard with a 2.68 60 and popped out of second on the other.
anyone see a way of improving this time. car has 1.6 rockers, cai, shortys, m6 lt1. tires are pirelli pzero 285/35/182.48 60ft
6.38 330ft
9.48 1/8
79.6 "" mph
12.1 1000ft
14.34 1/4
101.15 mph
altitude is 600'. seemed like a good night to me. on the pass where i missed 2nd i started reeling in a 07 gt. i do need to get some suspension work tho. right now i have bmr springs, agxs, and swaybars.
well guys i did a few more mods and am gonna hit the track again this weekend. I added 4.10s, lcas, reloc brackets. Also gonna take the 18s off the back and throw the front 275/40/17 comp T/As on the rear. I have some skinnies for the front as well and will disconnect the bmr swaybar. Last time i went the shocks were on full stiff in front since i hadnt touched them since the install so im guessing i should turn them to soft? ha any more advice or tips guys? i need to hit a 13
they arent unfortunately... just kyb agx's. other suspension is bmr springs, swaybars, lcas, reloc brackets, adjustable pb, stb. i see you have a similar set up on your 94 with some pretty good times. any other mods? whats your launch technique like? tires?
I would leave the shocks loose in the front for good front end rise on launch and come out just off idle, maybe slip the clutch at around 1500. With a t56 its a fine line between spin/bounce, and bog. Than with a good launch on sticky tires and a sticky clutch you start breaking rears and tranys. So thats why i usually leave the drag racing to my race car (with a th400 auto) and snag gears on the street in my 6 speed. Your travling into a very possibly expensive future.
Just my .02
Just my .02
i dont do any clutch dumps but before i eased off at 2k and spun hard with a 2.6 60'. i think it was due to my suspension but hopefully it should be okay now. this will be my last time to the track for a bit and also have a back up original rear so not too worried. ha and yeah this things a money pit but oh well. what rpm do you shift at? and thanks for the advice.
I shift at 6000/6200. The only mods I had at that time was homade control arms, a spohn adj TA (GET a good TA) and I had my pinion angle set at -5 degrees. And I had front sway bar removed. The first thing I would invest in is a GOOD clutch and a set of ET Streets. Than look up Taner on this board. Hes the **** when it comes to 6 speeds. Prorac1
checked out Taner and looks like he can drive lol. Well I went back a did a little better. didnt get a chance to switch tires or remove sway bar but maybe next time. it spun more in second and a little in third but picked up pretty good when it grabbed.
re .7044
60ft 2.345
330ft 6.238
1/8 et 9.351
"" mph 80.73
1000 et 11.98
1/4 et 14.17
"" mph 106.08
ran an ls1 this run that trapped the same but ran a 13.1
re .7348
60ft 2.331
330ft 6.186
1/8et 9.267
""mph 79.79
1000et 11.882
1/4et 14.051
""mph 105.26
4.10s,lcas, and reloc brackets made a decent difference even tho it was spinning more.
re .7044
60ft 2.345
330ft 6.238
1/8 et 9.351
"" mph 80.73
1000 et 11.98
1/4 et 14.17
"" mph 106.08
re .7348
60ft 2.331
330ft 6.186
1/8et 9.267
""mph 79.79
1000et 11.882
1/4et 14.051
""mph 105.26
looser those back wheels dude,
get stock f body 16" wheels with some mt et streets on em for track days if your gonna go often enough.
that alone will probbaly shave off 1-3 tenths depending on how bad your spinning
ha yeah these wheels suck for track use. Replacing the 18s with 17s next month. How are mt et streets on a 10 bolt
? Im getting a bmr adjustable torque arm and a mail order tune before next month's track event.
edit* Bought some mts on 16s instead.
edit 2* Went back 12-14 and managed to do a little better on the m/ts. Never used m/ts before so I didnt heat them up as I wasnt sure how they gripped. anyway, managed a 13.8 with a 2.2 60" and 13.7 with a 2.19 60". It spun pretty good off the line but they hooked at the end of first (heated up?). Doesnt spin second anymore though with m/ts
? Im getting a bmr adjustable torque arm and a mail order tune before next month's track event.edit* Bought some mts on 16s instead.
Z28Wilson
Aug 1, 2002 04:27 PM
