A Few N00B questions...
Old Jan 18, 2005 | 12:52 AM
fragenstein's Avatar
at the moment i have incredibly basic mods. Straight piped the cat... exhaust is just a dumped bullet. I cut the lid off my airbox. coolant bypass, 160 stat, pert shampoo mod, lous short stick. That's prolly most of it.
ANyway... my dad won't let me take it to the track till i finish paying for it this spring. I could do it anyway.. cuz I love across town in a dorm, but... i'm gonna wait.
Anyway.. I have some crappy BFG KDWS tires with alot of tread left. They leave somethin to be desired. I can't imagine my 60' times are better than 2.3 but I do not know.
Can anyone estimate what track numbers i may be capable of currently, and then an estimate of what i could do after LTs, 12-bolt, and nittos?
Drew
I may have some more Qs after I get some opinions on this.
Old Jan 21, 2005 | 02:59 AM
Re: A Few N00B questions...
ttt
Old Jan 21, 2005 | 08:23 AM
Mikey97Z's Avatar
I ran 13.3 @ 106 with a setup just like that.
Old Jan 25, 2005 | 07:16 PM
MellowZ's Avatar
Current setup is probably good for consistent low 14s. Might break the 13s if you get your launch and shifting down and have good conditions.
What gears would you put in the 12-bolt? Swapping in a 12-bolt with the same gears wouldn't make much of a difference in track times, though it'd be tougher.
Old Jan 26, 2005 | 12:15 AM
3.73s or 4.10s. Dont know if 4.10 is wise or not, since stock for an M29 is 3.23.
Old Jan 26, 2005 | 04:15 AM
MellowZ's Avatar
A lot of T56 guys seem happy with 4.10s. I'd recommend punching some numbers into an RPM calculator and deciding if you're ok with that much revving. Two important speeds are highway speed, and your expected trap speed in the 1/4.
Old Jan 26, 2005 | 03:33 PM
Yeah, "a lot" are happy with that, because MOST T56s (94+) have a 3.42 rear. While my final ratios are almost the same, my rear in my 93 is a 3.23 (M29 T56), and earlier 93s even had a T56 with 2.73 rear (M28). So a change to 3.73s for me would be very comprable to a 4.10 on a 94+ T56.
Old Jan 27, 2005 | 01:42 PM
LS1_03's Avatar
You want 3.73s. 4.10s would be too much.
blkWidow
Apr 20, 2015 09:27 AM
orbitalshock2k
Jun 2, 2004 02:24 PM
WheelmanZ28
May 9, 2004 03:58 AM
Type_O_Negative_1320
Mar 4, 2004 10:31 PM
ryan2
Feb 21, 2003 01:03 PM
