Fastest bolt-on car?
I'm curious to see what the fastest bolt on cars run. More interested in the LT1 than LS1 because i'll just get depressed when i see them. I'd guess there are some high 12's in there.
TONY
TONY
Re: Fastest bolt-on car?
More like a high 11.......I think that was only done by 1 guy with all the boltons and a pretty lightened car.
Others have made it mid 12's to low 12's with some weight reduction and some good suspension mods. In the future I would like to be mid to low 12's with bolt ons only and I think it is very much possible.
As far as bolt ons Im talking about the following
-Full intake/exhaust
-Headers
-Gears
-Higher stall if auto
-Elec. water pump
-1.6rr's
-tuning
-Drag radials/ full slicks
-lightened car / not gutted, just lightened
-Close to all of the suspension stuff, although if ya hook up then they arent all that necessary
-Underdrive pullies
-air foil
-tb bypass
-bigger throttle body
All that above stuff and you will be super quick and pulling some awesome times, but you may want to add a 12 bolt to the list cause its days will be numbered. But as far as high 12's with boltons, I would say that is fairly common if your car is running right.
-Headers
-Gears
-Elec. water pump
-1.6rr's
-tuning
-Underdrive pullies
-air foil
-tb bypass
I wish I could claim I was one. I am having hooking problems but my mph is pretty good at 112 with just bolt ons on an LT1. With traction, it might be somewhat impressive.
the 1.6rr issues has been debated over and over,and has been accepted as a bolt on. it was accepted for the GM High Tech Bolt on invitational.
I ran 12.36@109 with a bolt on car and i have a 9" moser rear,might of gone a tad quicker with a 10 bolt.
Originally Posted by Mindgame
Looks like 75% to me.
-Mindgame
-Mindgame
BTW, Kawasaki does have an assembly plant in the US, although I don't know if my bike was built here.
do a search ..been talked about time and time again. Record is held by SAR2K...11.96 I beleive at 111.xx. Every bolt on known to man, great air, and a dead hooking car on a great track.
Originally Posted by slimdawson
I was referring to myself
Yeah, search LT1 Tech for "Fastest bolt on LT1" and you'll find a few threads. Lots of cars running low 12's and Steve's high 11-second screamer. Think most of those low-12 guys abondoned the bolt-on thing and went on to strokers, internal-mod-engines and such. Good stuff.
-Mindgame
My times and mods are in the sig, however, I may have left out the free mods. Times were run prior to the Meziere. The only weight reduction I have done is to remove the spare and jack. Otherwise, I run on stock wheels on all four corners and my suspension is stock except for boxing the control arms and panhard rod and having relocation brackets on the 12-bolt. Race weight is 3640lbs.
Marty
Marty
I am hoping to run around 124 or so mph with my bolt on+boost LT1 and if I could hook like that
Hey man. Nice 60'. What size tire are you running? Rpms and gear through the 1/4?
I only seen high 12's in a bolt on Z, but hopefully high 11's w/the head/cam/fuel mod
We'll see how far I can take an automatic on bolt-ons before adding nitrous, as the Trans Am has been getting all the stuff the other car either outgrew or was replaced.
I ran 12's w/stock wheels, bfg drags, stock weight, ie: no weight reductions, slp subs, bmr lca's/panhard, bolt-ons including Moroso CAI & SLP headers/ypipe w/a gutted cat & flowmaster cat-back. LT4KM, RAM Clutch, TB free mods, Hypertech 160 stat, manual fan switch, No RR's, no internals whatsoever, stock water pump. Stock ignition w/NGK TR55's & shielded Accel wires.
