Dropping front sway bar??
Old Aug 21, 2002 | 07:34 PM
96z's Avatar
96z
Post Dropping front sway bar??
How difficult is this? Directions?
Would I be able to drive 1 hr to the track with no problems?
Gain if any?
Thanks.
96 black Z28 A4
GTP heads, GTP cam, bolt ons...
Mattucci Motorsports WNYFA FLFB
So far...12.7@108...need more practice...
The Z
Old Aug 21, 2002 | 08:43 PM
CANTONRACER's Avatar
Post
Just look at it. Not hard to do and have been driving without it now for a year and it is not really noticeable.
It does not weigh much though even with the brackets off.
1996 Z28 Camaro
2001 best 1/4 BFG DR's NA - 11.865@113.57 w/1.634 60', 1/8 - 7.563@89.82mph Best 1/4 MPH 114.82 - Best 1/8 MPH 90.73 - 2002 Mid 11's NA, Mid 10's n2o
1989 GMC 1500 truck for work 18.1@73 305
8 cats to feed clean after 1999 V6 Mustang 5 speed
15.358@89.47 MPH w/ 2.227 60'
15.364@90.92 MPH w/ 2.383 60'
My Z28
Old Aug 21, 2002 | 09:27 PM
kirschman's Avatar
Post
I took mine off couple months ago and unless you really like to hang the curves you wont notice the dif. Its no prob. to take off, and the weight transfer is worth it IMO
96Z M6, 12 bolt Moser(3.73),NX wet kit(all the goodies),MSD 6AL,tayor spiro-pro,NGK tr-6,Star stage 2 kevlar,pcmforless programing, SLP CAI,!maf,LT4 NM,Flowmaster,Hurst roll control,BFG DR's,Pro 5.0,BMR DS loop...
13.52-103.8 mph
60ft. 1.99
no n2o times yet
Old Aug 21, 2002 | 10:03 PM
Grease's Avatar
Thumbs up
I've ben driving for several months now without mine. As mentioned above, unless you are going to do some serious corner carving it won't really affect anything.
Green 1995 Z28, 6-Speed
Best ET: 12.616 @ 110.33 mph, 1.869 60ft
Race weight: 3430lbs
Old Aug 22, 2002 | 08:34 AM
jp2002ls1's Avatar
Post
I replaced mine with a larger one and it only took 15 minutes but with a 4 month old car when I took the end links off they were rusted a very little but they broke when I was taking them off so you might want to buy some new ones, poly end links only $10. I plan on simply disconnecting the end links when I get to the track and I should get approximately the same effect of taking it off by the suspension flex but I love cornering so I wouldn't leave mine off. Good luck.
Old Aug 22, 2002 | 08:56 AM
blkchevyz's Avatar
Post
i just took mine off... i did notice the car does handle bad but the et streets and skinnys dont help much either.
like someone else said you will need to get some new endlinks.
Old Aug 22, 2002 | 04:05 PM
96z's Avatar
96z
Post
I would be dropping it just for track duty. Would it still be worth it?
RUENUF
Mar 13, 2016 03:39 PM
Alien
Jun 27, 2015 01:13 PM
96SilverRam
May 28, 2015 02:09 AM
96SilverRam
May 5, 2015 09:56 PM
8T8IROC
Mar 26, 2015 09:02 PM
