drag seats with no cage?
I use a set of Kirkey aluminum seats on the factory manual sliders, it works for me. I use a set of Simpson 5 point harnesses with them. As far as safety goes, I race at NHRA and IHRA tracks and the tech inspectors had no issues with them. I built a small perimeter frame inside the seat to stop the bolt/nuts from pulling thru, that was my only concern.
I'm getting ready to add a rollbar to my car because I'm getting closer to the 11.49 bar cut off.
To the best of my knowledge There are no 5 point harnesses meet DOT regulations
Order the long Simpson Harnesses, you can then use the 2 factory front seatbelt holes for the lap belts, then use the 2 factory rear seatbelt holes for the harness belts, then drill a hole in front of the seat for your submarine belt. Thats how I did it.
