Is this a decent time
Old May 12, 2006 | 05:13 AM
quick98's Avatar
This is my first LT1 (Always had LS1's) so I don't really know what they are supposed to run stock but I took it out tonight and got some times. The car is completely stock down to the paper filter and is a '97 auto with 3:23 gears. I was on 315 Nitto DRs @ 15psi.
2.1 60'
9.3 1/8th
76 mph
Old May 12, 2006 | 07:30 AM
AL SS590 M6's Avatar
Moderator
Re: Is this a decent time
2.1 60'
7.3 1/8th
76 mph
Shouldn't that be 9.3 @ 76 ?
Old May 12, 2006 | 09:22 AM
The Engineer's Avatar
I have headers, LT4 Hot Cam, 3200 stall, 3.73s, suspension work and MT ET Streets with a best 1/8 ET of 7.79 (12.17, 1/4). Therefore, I don't believe a 7.30 is possible with a stock LT1! The 7.30 would be equal to an 11.40 in the 1/4, again not possible.
Old May 12, 2006 | 09:28 AM
quick98's Avatar
Yup 9.3 is what I meant. I only got two hours of sleep last night so I'm a little tired.
So what about a 9.3, is that alright?
Old May 12, 2006 | 11:25 AM
I8ASaleen's Avatar
That's a fair time and the E.T. looks correct. Some run 8.8's and some run 9.8's it all depends on the driver and how well it's been maintained. Good times though...
Old May 14, 2006 | 10:51 AM
Soccerbum21's Avatar
i run about 9.2 off the bottle.
i got the moroso intake, cat back, and a mild computer tune.
oh yeah, 2.73 gears on mine...but yours looks about right for stock to the paper filter.
but on the bottle and my ET Streets i am cutting 1.5 60' with 7.7 @ 88...so you should spray it
Old May 14, 2006 | 12:04 PM
trymy6's Avatar
Wow I need to hook. I run the same 88mph in the 1/8th as you on the bottle but went 8.99 with a 2.30 60ft. I can't even spray until 4,000 in second if I want it to even try to hook....
Old May 14, 2006 | 07:12 PM
quick98's Avatar
Nice times on spray!! I definitely plan on spraying but there will also be a built 355 with heads/cam, stall, and all that good stuff.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
grabbem88
Feb 17, 2015 07:49 AM
grabbem88
Feb 13, 2015 03:09 PM
HectorM52
Jan 30, 2015 11:08 PM
