Calling all 255/50/16 et street radial guys
I run mine at 22lbs. cold, or there abouts. Dead hooks every time on test and tune nights. (no track prep) My 3600 drives just fine on the street with the 3.73 gears. Higher gears equals more gas pedal to get going.
20Psi for me. The pressure doesn't fluctuate too much from cold to hot in these tires. M6 fullweight, 16x8's all around low 1.70's consistantly. I actually do better with 20-22psi then lower pressures.
and i have heard around 16 psi cold in these tires are the best... i dn tho
You want as much air as possible and still have traction. To little air and you might screw up the footprint of the tire. My Nittos like low air pressure, the MT don't need to be run that low.
Start at 22 or 21 make a couple of passes and if they spin then lower them one psi at a time 'till you find that they hook better or get worse.
