Burnout tips
Re: Burnout tips
Originally Posted by IHI
AND it could possibly just be the water box itself, do you happen to notice other cars consistantly "kicking out"?
Re: Burnout tips
Originally Posted by Nick 02 Z06
My guess is that it's something simple like unequal tire pressure or the dip in the water box isn't equal in depth or width from one end to the other......... Correct me if I'm wrong but aren't Mickey Thompson Drag Radials a treadded tire? If so, I would avoid the water box like the plague and bake those tires until the smoke completely engulfs the car and then see what your sixty foots look like.
Re: Burnout tips
Originally Posted by JS02
Did you check the rollout on the tires. Sometimes the tires may stretch unevenly. You may have to put more air in one tire to make them even.
97 SSM6
97 SSM6
I know both tires had the same air pressure, but I never thought about measuring the rollout on a radial tire. I've done it countless times on a bias-ply slick, so I may just check them to be sure.
autoxr166
Sep 25, 2015 04:21 PM
