if you have 3.42 gears then you are not stock because I'm pretty sure A4 camaro's only came in 2.73 and 3.23 gear ratios. With 3.42 and sticky tires I would say low 1.9 60 foots and maybe a 1.8, just depends on how strong your car is. With my crappy 2.73 gears and Bfg Dr's I pulled a best of 2.000 60'.
The best I've gotten so far has been 1.920 running my street tires!!
Even my BFG DR's only cut a 1.94 I think?
This is with my current 4.10's and factory stall (and the car bogs seriously out of the hole
With the stock 2.73's, the best I ever got was the 2.152 that's in my sig. However, that was on the original Goodyear Eagle RSA's, which didn't hook at all in comparison to my new tires (Hankook Ventus II HR405's.................cheap, but they work!
).With the stock 2.73's, the best I ever got was the 2.152 that's in my sig. However, that was on the original Goodyear Eagle RSA's, which didn't hook at all in comparison to my new tires (Hankook Ventus II HR405's.................cheap, but they work!
).Registered User
I pulled a 2.0 60' in my Cobra with a little spin with the stock F1's...
Then I bought these:
http://www.wheeltech.com/tires/goodyear/f1gsd3b.jpg
http://www.goodyear.co.jp/images/nr/20031003-1.jpg
Instantly went to 1.89
So I also just bought a pair for my WS6 and after 10 miles or so I decided to test them out!
The only problem is it started to rain.. I was like DAMN RAIN!!! Well I figured I needed to test their ability to handle rain as well so I floored it in 1st from 25oo RPM's and the damn car took off like it was DRY!!!
They are spendy as hell but they kick major azzzzzzzz over a regular Eagle F1!!!
